06-21-2004 11:22 PM - edited 03-02-2019 04:31 PM
I have a catalysts 5509 using CatOS 4.5(4) and the cabling is a lil bit messy now. I have many switches connected to it (3com, and cisco 2900's). My problem is how to check to which port are the traffic goin out. Say in the old inventory I have the data that
one 3com switch is connected to port 2/4 but over time they changed it,
5509(port 2/4)------goin to---(port 1 of 3COM).
Question:
How to verify using show commands in the 5509 CLI
that the 3COM which is indeed connected through port 2/4 of the 5509. Is there a way? given only the
MAC address of the 3COM switch, say the edge switch has no management ip. Even if the edge switch is a cisco with a management IP, I still dont know how to
verify to which port in the core it is connected.
Your help is very much appreciated, so that I dont need to go through the forest of cables.
06-21-2004 11:39 PM
If your looking for a directly connected Cisco device you can simply use 'sh cdp neighbors' (check CDP is enabled at both devices).
If your looking for another device (3com switch) and you know its MAC address you can try
'show cam XX-XX-XX-XX-XX-XX'
where XX-XX-XX-XX-XX-XX is that MAC address.
06-23-2004 10:19 PM
Hi Jolmo,
I tried it, i noticed that the switch is receiving alot of MAC address from a specified port, I guess this is the normal behaviour.
Rj
06-23-2004 10:42 PM
That's beacuse there is a switch or a hub connected to that port.
