How to Connect SFP-10G-SR module with MGBSX1 module through patch cable.
rajkiran.p1
Good Morning All,
I have SG500X series  with SFP-10G-SR and SF350 Series switch with MGBSX1 module.
How can i connect both switch through patch cable.
Philip D'Ath
One is a 10Gbe module, and the other is a Gigabit. So you wont be able to connect them both together.
Thanks Mr. Philip,
is any possible to connect both end using converter.
Replace the SFP-10G-SR with a Gigabit one.  Then you can connect them using a fibre patch lead.
Thanks Mr. Philip.
