How to replace failed supervisor module IV on Cisco WS-C4506
shaunjabrook
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12.2(25)EWA5. Cisco has RMA a new supervisor module. Please advise what are the steps to replace a failed sup mod
5 Replies 5
dnewell24
Installing and Removing the Supervisor Engine for Catalyst 4500
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_installation_guides_list.html
Scroll down to the Supervisor Engine Notes section and locate your supervisor model.
Prashanth Krishnappa
If you have compact flash card, back up the configs and IOS to the flash card. Swap out the Supervisor, use the IOS and config on the compact flash card to boot the new Supervisor.
PS: Remember to rate useful posts.
Good point..
To be clear on my side - as i have never replaced a failed sup module before - i would take the following steps - i do have about 122 mb free on slot0:
copy bootflash: slot0:
cat4000-i5s-mz.122-25.EWA5.bin
running-config
Then - I should be able to hotswap the failed sup module with the new one.
copy slot0: bootflash:
running-config
Verify
Please advice - thanks
Hi Friend,
AFAIK to copy image from bootflash to slot0 and vice versa is ok but to copy config you muct run the command
copy config slot0:
and for putting it back
copy slot0: config
Check this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/8_1/cmd_ref/cl_t_ses.htm#1062281
HTH, if yes please rate the post.
Ankur
