HTTPS/SSL/PPPoE Issue
offlinetn
Community Member
We are currently running a Windows SBS 2003 w/ exchange & IIS server. Our Cisco 831 is connected to our ADSL provider with PPPoE. Our IIS server is behind the Cisco IOS's NAT and Firewall. I can view regular HTTP pages from the internet but I cannot view any HTTPS pages. Here is a copy of most of my config. Any help would be greatly appreciated. Thanks!
aaa authentication login default local
aaa authorization network groupauthor local
aaa session-id common
ip subnet-zero
no ip source-route
no ip domain lookup
ip domain name router.thetruck.com
ip name-server!
no ip bootp server
ip inspect audit-trail
ip inspect name IOSFW ftp
ip inspect name IOSFW h323
ip inspect name IOSFW http audit-trail off
ip inspect name IOSFW tcp
ip inspect name IOSFW smtp
ip inspect name IOSFW udp
ip audit attack action alarm drop reset
ip audit po max-events 100
ip audit protected
ip audit protected 192.168.100.1 to 192.168.100.254
ip audit protected 192.168.101.1 to 192.168.101.254
ip audit smtp spam 30
ip audit name ARFW info action alarm
ip audit name ARFW attack action alarm drop reset
ip ssh time-out 60
vpdn enable
vpdn logging
vpdn-group 1
request-dialin
protocol pppoe
ip mtu adjust
no ftp-server write-enable
crypto isakmp policy 2
encr 3des
hash md5
authentication pre-share
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp key xxxx address 172.x.x.1
crypto isakmp key xxxx address 172.x.x.3
crypto isakmp client configuration group thetruck
key cisco123
dns 192.168.100.20 192.168.100.21
wins 192.168.100.20
domain thetruck.local
pool ippool
acl 160
crypto ipsec transform-set thetruck.com esp-des
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map btdynamic 10
set transform-set myset
crypto map thetruck.com1 local-address Dialer1
crypto map thetruck.com1 client authentication list default
crypto map thetruck.com1 isakmp authorization list groupauthor
crypto map thetruck.com1 client configuration address respond
crypto map thetruck.com1 100 ipsec-isakmp
set peer 172.172.172.1
set transform-set thetruck.com
match address 100
crypto map thetruck.com1 101 ipsec-isakmp
set peer 172.172.172.3
match address 101
crypto map thetruck.com1 102 ipsec-isakmp dynamic btdynamic
interface Ethernet0
ip address 192.168.100.1 255.255.255.0
ip access-group 150 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip inspect IOSFW in
no ip mroute-cache
no cdp enable
hold-queue 100 out
interface Ethernet1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip audit ARFW in
no ip mroute-cache
duplex auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
mtu 1492
ip address xxx.xxx.xxx.xxx 255.255.255.252
ip access-group 151 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip audit ARFW in
encapsulation ppp
ip tcp adjust-mss 1300
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxx password xxx
ip local pool ippool 192.168.101.2 192.168.101.254
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.50.0 255.255.255.0 Dialer1
ip route 192.168.101.0 255.255.255.0 Dialer1
ip route 192.168.200.0 255.255.255.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer1 overload
ip nat inside source static tcp 192.168.100.20 80 interface Dialer1 80
ip nat inside source static tcp 192.168.100.20 443 interface Dialer1 443
ip nat inside source static tcp 192.168.100.20 444 interface Dialer1 444
ip nat inside source static tcp 192.168.100.20 25 interface Dialer1 25
Richard Burts
Chris
Your config references several access lists that might affect what is happening (100, 101, 150, and 160). But none of these access lists are included in what you posted. Can you post at least these access lists?
Rick
Rick
Here they are... THANKS!
ip access-list extended tty0
logging trap debugging
logging 192.168.100.50
access-list 100 permit ip 192.168.100.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 100 permit ip 192.168.101.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 101 permit ip 192.168.100.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 101 permit ip 192.168.101.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 102 deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 102 permit ip 192.168.0.0 0.0.255.255 any
access-list 150 permit ip 192.168.0.0 0.0.255.255 any
access-list 150 deny ip any any log
access-list 151 permit icmp any any
access-list 151 permit tcp any host xxx.xxx.xxx.xxx eq smtp
access-list 151 permit tcp any host xxx.xxx.xxx.xxx eq 22 log
access-list 151 permit tcp any host xxx.xxx.xxx.xxx eq www
access-list 151 permit tcp any host xxx.xxx.xxx.xxx eq 443
access-list 151 permit tcp any host xxx.xxx.xxx.xxx eq 444
access-list 151 permit ip host 172.172.172.1 host xxx.xxx.xxx.xxx
access-list 151 permit ip host 172.172.172.3 host xxx.xxx.xxx.xxx
access-list 151 permit udp any host xxx.xxx.xxx.xxx eq isakmp log
access-list 151 permit esp any host xxx.xxx.xxx.xxx log
access-list 151 permit ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 151 permit udp any host xxx.xxx.xxx.xxx eq non500-isakmp
access-list 151 permit ahp any host xxx.xxx.xxx.xxx
access-list 151 deny ip any any log
access-list 160 permit ip 192.168.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
no cdp run
