hub connected to a switch port configured as vlan
cro9uk
Hi, what would happen if a port on a switch (2950)
was configured as vlan 3 and had a hub (non cisco) connected to it? would all the clients in the hub be placed into vlan 3? or is it not that simple.
paddyxdoyle
Level 6
Level 6
They would be in VLAN3. We came across minor issue using Hubs when we were waiting for data ports to be installed. We used a different VLAN for our printers so any printers that were in a hub that was also used for users had to have an address reserved from our user VLAN DHCP scope purely because the switch port connecting to the hub was in the user VLAN.
Also make sure that portfast is NOT enable on your switch ports connecting to the hub
Rgds
Paddy
