I need help.
salgio
I got two lan separeted by two routers Cisco 1600 and a serial cable, with hosts win 2k at both side.
All is working fine: ping, tracert and I can map every host from every host. I got no server D.N.S, only workstastions with files lmhosts compiled.
The problem is: why in network neighborhood the workgroup of the opposite lan do not appeare automatically?
Must I use necessarily D.N.S. servers?
In the configurations files of the routers I have activated: ip directed-broadcast.
Thanks.
donewald
Level 6
Level 6
It's been awhile for the Microsoft stuff but here goes...
For browsers to exchange information between layer 3 networks you need a WINS server that all hosts register with. I believe this would allow you to see all your hosts in network neighborhood. On local layer 2 segments the browse master will allow all your hosts within a workgroup/domain to see each other. This (WINS) is pretty easy to setup if you have an NT Server somewhere in your network.
Hope this helps,
Don
Thank you Don for your help,
Giovanni
efrahim
Level 4
Level 4
this is very good URL for your ref.
http://www.cisco.com/warp/customer/473/winnt_dg.htm
thank you for the intormation but I am not able to reach the url because it doesn't accept my user name and password, and if I must make a new registration I should be CCIE which I am not.
If you are so kind to send me the page by email, I will appreciate. My mail is: gbsalerno@libero.it
