10-14-2002 02:56 AM - edited 03-02-2019 02:03 AM
Hi All,
I would like to know if there is a way to upgrade an IGX firmware using a PC with Windows XP as operating system.
the SVLITE software can't work on this OS, so i hope that there is another software that can do it.
please let me know any news, links, forum and whatever you think could be usefull.
thanks a lot
Simone
10-14-2002 04:12 AM
Simone,
You can upgrade the firmware or switch software on the IGX if you have lan connectivity to the box and a tftp server and client installed on your PC, regardless of the operating system on it. Please check the following links from CCO that explain in detail how to do this.
http://www.cisco.com/warp/public/74/156.html
10-14-2002 06:35 AM
Thx a lot for your info, i'll try this way.
if there are other way to do it please let me know.
"ciao" from italy
