Input/Output rate in bps with or without Ethernet header?
ricart.cortinas
I'm not sure about the data I'm collecting by my Cacti (MRTG) server or by the output of a show interface command.
The input or output rate in bits/sec includes meassurement with Ethernet header? It is usually not important as pakcet size is much greater. My question becomes important when packet size is of 29 bytes, due to a DDoS attack and want to know if the amount of Mbps of my SNMP grpahics are including or not the Ethernet header in the calculation.
Example of the show interface:
FastEthernet0/1 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0016.47e9.04df (bia 0016.47e9.04df)
  Internet address is 10.0.0.47/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:02, output 00:00:02, output hang never
  Input queue: 0/4096/0/6 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/4096 (size/max)
  5 minute input rate 1000 bits/sec, 4 packets/sec  --- Does it include 20 to 30bytes of Ethernet header per paecket in this average rate?
  5 minute output rate 25000 bits/sec, 3 packets/sec --- Does it include 20 to 30bytes of Ethernet header per paecket in this average rate?
     3556080 packets input, 225842679 bytes
     Received 1483940 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     2257306 packets output, 1751375346 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
On a 7200 routers, a gigabit ethernet is a layer 3 interface, and chances are is that layer 2 overhead is not included in counters.
Bits per second are calculated with a time-biased formula that has never been divulged.
However the input to bitsp per second is the interface counter, so they are directly related.
5 Replies 5
paolo bevilacqua
For a layer 2 interface, it should include Ethernet header and CRC. But you should double check looking at the input bytes counter, because sometime there are bugs in this regards.
Thanks Paolo for your comment.
In any case, on a Cisco 7200 or ASR1000 routers, I understand a Gigabit Interface is treated as layer 2 interface, even when definning subinterfaces per vlan.
Expanding my question:
Should I expect that bps (bits per second) counter and pps (packet per second) counter are updates separately? I mean, not relationed by an arithmetic formula...
Thanks in advance. Comments are wellcome.
That helped me very much.
You sound really much more sure than myself unable to find any related document explainning clearly this point.
Thanks for your comments.
Thanks for the nice rating and good luck!
