input queue drops
MARCELO MATURO
Level 3
Level 3
I have an RSM router in a Catalyst 5509 module. There are several vlans and I have a lot of input queue drops in vlans interfaces. I have raised the hold-queue to 200 in each interface, but the problem continues.
Thanks. Regards
20 Replies 20
Ok, the two VLAN interfaces that are experiencing the throttles, are they the two most heavily populated (ie devices attached)?
I would suggest upgrading your IOS image to 12.0(8), although that will not resolve the problem as there are no bugs like this in that level of code.
It could be as simple as a Netware server getting very chatty at certain times in the day, possibly a backup being set off or something. I presume you run FastEthernet?
Also, if you have 600 devices on each VLAN, they are slightly over populated and you might want to consider splitting the VLAN into two smaller VLANs
Daniel,
yes, that are the most populated vlans. On the other hand there are people working for leave from Novell. I suppose this fact will improve the perfomance.
We are working too to eliminate transparent bridging between vlans.
Marcelo,
michaeljmorris
Level 2
Level 2
do a "show buffers". Are you getting failures for "no memory". You may need to tune your buffers :
http://www.cisco.com/warp/public/63/buffertuning.html
The result of show buffers is ok:
Buffer elements:
499 in free list (500 max allowed)
772756847 hits, 0 misses, 0 created
It isn't a buffer problem - if you look at Vlan 5 stats, no packets were dropped due to no buffers
what version of code are you running?
daniel.bowen
Level 5
Level 5
Also, try to work out if there is some kind of traffic storm in your network occuring at certain times. If so, try to gather some stats from the RSM during this storm
sh proc cpu
sh proc mem
sh buffers
sh int "affected interfaces"
these commands should produce all the relevant info
