01-02-2003 09:48 PM - edited 03-02-2019 03:54 AM
I'm setting up a trunk port on a 2924 switch thats connected to a 7206vxr...
On the router, fa0/0 has several secondary ips listed under it.. In moving over to a trunk port which would be "better practice". To make one sub interface per vlan w/ lots of secondary ips OR several different subinterfaces one for each ip..
Example..
interface FastEthernet0/0.1
encapsulation isl 2
ip address x.x.x.x 255.255.255.0
ip address x.x.x.x 255.255.255.0 secondary
or
encapsulation isl 2
interface FastEthernet0/0.2
encapsulation isl 2
interface FastEthernet0/0.3
encapsulation isl 2
interface FastEthernet0/0.4
encapsulation isl 2
01-03-2003 12:58 AM
if you want to route between VLANs, you need a subinterface in each VLAN on the router side, i.e.:
encapsulation isl 1
encapsulation isl 2
encapsulation isl 3
encapsulation isl 4
If you put several secondary IPs on one subinterface (as you mentioned) they would be all in the same VLAN and you wouldn't be able to route between VLANs.
HTH,
Milan
01-03-2003 06:44 AM
If you are creating vlans, then you def. need subinterface with right vlan number. In the above subinterface config, you put encap isl 2 under every subinterface, that would not work. every subinterface suppose to belong to different vlan.
If you put all the networks under one subinterface then it would only belong to same vlan which in your case 2 but on different networks.
For your ref,
