IOS Ugradie Problem 801 Router
NeedCiscoHelp
i got an old Cisco 801 Router from the company i work because they dont have any use for it!
Now i wanted to do an IOS-Upgrade, but i have a problem upgrading the IOS from TFTP-Server!
I am doing exactly the way how it is discribes in the cisco sheet fpr ios upgrade:
who can tell me what the following erro means, and what could cause it!!
boot# upload tftp
TFTP initiated.
Build [dchih 9] -- Fri May 14 11:04:10 PDT 2004
File name: c800-oy6-mw
RAM size: 0x00b27675 (11695733)
Raw size: 0x00a610cd (10883277)
Image size: 0x0050593c (5265724)
Error 7 at offset 884576.
upload: failed (7 seconds), "buffer overflow"
boot#
jamey
Level 4
Level 4
Could be not enough space on flash (did you erase it prior to copying the new image).
More likely though, it is the router doesn't have enough RAM for the image you are trying to copy. Check that out. You could try a different image.
Lastly, it could be the tftp server you are using (unlikely though)-try tftpd32-http://tftpd32.jounin.net/
Also, here's the procedure page on upgrading 801s...
http://www.cisco.com/en/US/products/hw/routers/ps380/products_tech_note09186a0080117772.shtml
now i tried to upload the ios by xmodem,
but there i have the same problem
It always stops at the same number of transfered
bytes!
What could the problem be?
Can I solve it anyway or should I
give up hope!
Does anybody know a solution for my problem?
