IP cache flow on a 4506 switch
mulhollandm
folks
i'm using a piece of software called netflow monitor to look at traffic over my routers but i was hoping to use on my large chassis based switches
on my 4506s i can configure them with the ip flow commands, i.e.
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 10.*.*.* 2055
ip flow-cache timeout active 5
but the source interface doesn't recognise
ip route-cache flow
when i run a show ip flow export command there is no info being exported
anyone any ideas/advice
thanks to anyone taking the time to respond
amikat
Level 7
Level 7
This command does not work on the per-interface basis in Cat4506. Try to set in global config mode, you should have supIV with NetFlow Service card installed.
Best regards,
Antonin
antonin
many thanks for your reply
gratefully appreciated
