IP Mobile - same router
les.flack
Hi, I have a client with an office LAN based on 6500 acess with collasped distribution/core on two 6500/sup720's. He has a requirement for maintaining the same IP for a laptop when it moves from the IT support LAN to user LAns.
IP mobile sems to fit the bill BUT - can I configure both a home agent and a foreign agent on the same Router?
For a small number of mobile IP's are there any concerns for configuring the foreign agent on production user LAN's?
rgds
dwgray0422
you shouldn't have any issues running FA on any VLAN. check into LAM if you are only using one host, it may be better suited for your needs.
