12-16-2004 03:14 AM - edited 03-02-2019 08:37 PM
Wired properly, does CAT 5 Ethernet cable meet specs to provide the connection between the Telco access point and my router interface (U connection)?
Solved! Go to Solution.
12-16-2004 03:46 AM
12-16-2004 03:46 AM
CAT5 is fine, you can even use CAT3.
GP
12-16-2004 05:40 AM
Thanks. Information is getting "pretty sketchy" on ISDN. But I'm in a rural community and found it is my only choice to deploy (besides dialup). Have to construct a cable longer than the 6 footer that came with router.
