Latency Problem
tarun209
Hi Friends
I have got a setup where there are two core switches with vlans created on them.when i try to ping from a pc which is directly connected to core switch i got 10ms to 15ms response in between.This is happening in all vlans
Here is the core config
Using 4247 out of 524280 bytes, uncompressed size = 22351 bytes
Uncompressed configuration from 4247 bytes to 22351 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service compress-config
hostname EVS-Core1
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
ip subnet-zero
no file verify auto
spanning-tree mode pvst
power redundancy-mode redundant
vlan internal allocation policy ascending
interface Port-channel1
switchport
switchport mode trunk
interface GigabitEthernet1/1
channel-group 1 mode on
interface GigabitEthernet1/2
interface GigabitEthernet2/1
interface GigabitEthernet2/2
interface GigabitEthernet2/3
interface GigabitEthernet2/4
interface GigabitEthernet2/5
interface GigabitEthernet2/6
interface FastEthernet3/1
switchport access vlan 3
switchport mode access
spanning-tree portfast
interface FastEthernet3/2
interface FastEthernet3/3
interface FastEthernet3/4
interface FastEthernet3/5
interface FastEthernet3/6
interface FastEthernet3/7
interface FastEthernet3/8
interface FastEthernet3/9
interface GigabitEthernet6/48
switchport access vlan 10
interface Vlan1
ip address
interface Vlan2
ip address
ip helper-address
no ip redirects
standby 2 ip
standby 2 priority 110
standby 2 preempt
interface Vlan3
ip address
ip helper-address
no ip redirects
standby 3 ip
standby 3 priority 110
standby 3 preempt
interface Vlan4
ip address
ip helper-address
no ip redirects
standby 4 ip
standby 4 priority 110
standby 4 preempt
interface Vlan5
ip address
ip helper-address
no ip redirects
standby 5 ip
standby 5 priority 110
standby 5 preempt
interface Vlan6
ip address
ip helper-address
no ip redirects
standby 6 ip
standby 6 priority 110
standby 6 preempt
interface Vlan10
ip address
ip helper-address
no ip redirects
standby 10 ip
standby 10 priority 110
standby 10 preempt
ip route
ip http server
line con 0
stopbits 1
line vty 0 4
no login
ntp authentication-key xxx
ntp authenticate
ntp trusted-key 1
ntp clock-period 17179342
ntp server 172.16.1.1
end
Can anybody suggest whatmay be the issue
Tarun
Prashanth Krishnappa
ICMP destined for the switch itself is a low priority task. Try pinging from a device to another device(this way the ping packet is like any other data packet for the switch).
http://www.cisco.com/warp/public/473/82.html#ping
