05-11-2004 05:13 PM - edited 03-02-2019 03:38 PM
I had tried to load balance or failover between an ISDN line and ADSL connection based on config below.It only work on ISDN line but once I used a single ADSL connection without the connection from ISDN it just work perfect.
Cisco1750#show run
Building configuration...
Current configuration : 1850 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco1750
boot-start-marker
boot-end-marker
enable password xxxxxx
memory-size iomem 25
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
isdn switch-type basic-net3
interface BRI0
description connected to Internet
no ip address
ip nat outside
encapsulation ppp
dialer rotary-grou
dialer-group 1
no cdp enable
interface Ethernet0
ip address b.b.b.b 255.255.255.0 "global ip"
ip nat outside
half-duplex
interface FastEthernet0
description connected to EthernetLAN
ip address 192.168.x.x 255.255.255.0
ip nat inside
speed auto
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
no ip split-horizon
dialer in-band
dialer string 1525
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp authentication c
ppp chap hostname abc
ppp chap password xxxxxx
ppp pap sent-username abc password xxxxx
router rip
version 2
passive-interface Dialer1
network 192.168.253.0
no auto-summary
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 102 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 b.b.b.b "gateway for the ADSL connection"
no ip http server
access-list 1 permit 192.168.x.x 0.0.0.255
access-list 102 permit ip 192.168.x.x 0.0.0.255 any
dialer-list 1 protocol ip permit
snmp-server xxxx
snmp-server enable traps tty
line con 0
exec-timeout 0 0
password xxxx
login
line aux 0
line vty 0 4
password xxxx
login
end
Cisco1750#
05-12-2004 01:49 AM
This is not a proper configuration; you should not have two default routes active at the same time.
This causes the following problems:
- Out of sequence packets.
- Inproper load balancing due to unequal cost paths.
- Extensive retransmission in case of lost packets.
Besides all this misery, it is very likely that your return path will be either ISDN or ADSL. Your load balancing will only work in one direction. Check it!
My advice would be to forget about load balancing in this situation. To get this working properly, you have to adjust the provider side as well.
Leo
05-12-2004 08:49 AM
First replace this:
With this:
ip nat inside source route-map Ethernet0 interface Ethernet0 overload
ip nat inside source route-map Dialer1 interface Dialer1 overload
route-map Ethernet0 permit 10
match ip address 102
match interface Ethernet0
route-map Dialer1 permit 10
match interface Dialer1
This should make the NAT work probably, if howerver your 2 default routes have the same administative distance, check by doing a "sh ip route".
You should see somthing like this:
S* 0.0.0.0/0 [1/0] via b.b.b.b, Ethernet0
[1/0] via d.d.d.d, Dialer1
This config will make equal load balancing over both lines, this works OK if both lines have the same bandwidth, however if you have 128 Kb on the ISDN and 256 on the ADSL you need to make it unequal load balancing using static routes.
I haven't done this myself, but I'm sure you can find it on the cisco page.
Good luck.
