manageable switch port monitor
ccrespoh
Hello all,
I'm looking for a switch port monitor capable. 8 or 16 port 10/100. What I really need is the port monitor.
I want a cheap one, and I've looked for in the linksys series. Which switch is as I'm looking for? Which one do you recommend me?
Thanks in advance
Prashanth Krishnappa
Couple options I can think off.
1)You might want to look at the 2950/2960s which run IOS and support Port monitor feature.
2)Basic SPAN feature is supported in CE-500 switches but they cannot be managed via telnet but you will need to use Cisco Network Assistant(CNA).
Hope this helps.
PS:Remember to rate useful posts.
I've thought about the 2950/2960, but their prices are so high (600 euros).
The CE-500 one are out-of-sales. Do you know which it is the new model?
Thanks again.
