07-18-2004 10:06 AM - edited 03-02-2019 05:08 PM
I Have a 64 k line which i am using for
connecting to the internet so that poeple
can send and receive mail through microsoftexchange server 5.5. I have implemented NAT
and access-list to permit mail through the
NAT interface. What stratles me is that the
64 k line seems to be at peak use all the time
and I dont believe this is the mail traffic
which is causing this. How can I check traffic typeS
passing through this interface and their port numbers
so i can block them? i.e only accept pop3 and smtp and probably www.
07-18-2004 10:19 AM
possibly one of the workstations on your network is infected with a virus or some other spyware. You could turn on ip accounting on the outgoing interface to see which source and destination address pair uses up most of the bandwidth. If e.g. your outgoing interface is Dialer1, configure the following on that interface:
interface Dialer1
ip accounting
ip accounting output-packets
In order to view the collected data, type:
Router#show ip accounting
HTH,
Georg
07-18-2004 01:44 PM
You could use netflow, to give you more accurate information. Netflow gives source and destination ip address, source and destination port, source and destination interface and ip protocol type. You will be able to know what traffic or host is really congesting.
On the interface, enable netflow by typing ip route-cache flow. Then do a show ip cache flow.
Also, you could use nbar.
