Max length StackWise Cable
g.leonard
Level 4
Level 4
I have read that 1m and 3m cables are available in addition to the default 0.5m StackWise cable. Is 3m the maximum length available.
Basically I am looking to connect switches on different floors utilising the 32Gbps connectivity provided, or is this not possible or is there a better way to get high bandwidth between floors? TIA
johansens
Level 9
Level 9
Yes, 3m is the maximum length available.
Use multiple connections in a etherchannel to get more bandwidth between the floors:
Check these links:
"How to configure port channeling on the Catalyst 2900XL, 3500XL, 2940, 2950, 2955, 2970, 3550 or 3750 series switches"
http://www.ciscotaccc.com/lanswitching/showcase?case=K57123019
"Understanding EtherChannel Load Balancing and Redundancy on Catalyst Switches"
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
Did it help? If so, please rate it.
johansens
Level 9
Level 9
Check these links:
