Modem Chat-script help
lovedam
I am trying to get my 3725 to dial into an ISP and run PPP.
I have a script that looks like this
chat-script unix-ppp ABORT TIMEOUT 60 " " login: "me@ppp" password: "test123"
I have the script attached to the line corresponding to where I am dialing out (I have an 8 port modem card). I have the script set for "activation."
when I debug the script and dial the debugs say that the script has started and the first thing says "expecting " "
Then it says that remote end is not respnding and the line timeouts and the call drops.
I know this ISP works as does the username/password because I have dialed in with a windows PC.
The ISPs login looks like
** welcome to XXX ISP **
login:
password:
Does anyone have experience making chat-scripts to handle this? (I don't!)
Mine looked right, but doesn't seem to trigger.
Any help would be greatly appreciated.
Also, do I no longer need to send a pap user name ?
(in other words, do I need to erase the command "pap sent username *****" from the Async line config?
Thanks in Advance
Kevin Dorrell
Level 11
Level 11
Try taking out the ABORT keyword, or follow it by ERROR. I think it is expecting ABORT to be followed by a condition under which it should do the abort. That is getting confused with your next keyword, TIMEOUT. The arguments after the chat-script name should be grouped in pairs.
I know you probably have the documentation already, but here it is again for reference:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_r/drfchcp.htm#wp1018177
Kevin Dorrell
Luxembourg
dbellazetin
Level 7
Level 7
I'm not sure what your config looks like but I would follow an example like this.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080093d2a.shtml
You need to pass your ISP the username and password using the pap sent username command.
Do not insert the login info into the chat script.
Daniel
