monitor e1 controller
rprajapati
Community Member
hello
we're using a cisco5300 for e1 dialup connections. as the ras is located in a public place , the e1 cable frequenty becomes dislocated from the ras. i m not so familiar with snmp. it seems typing in my linux machine
"snmpget router_name community_string system.sysUpTime.0" gives me the system up time. in the same way what is the command to see the e1 controller up/down?? much obliged for help
rmushtaq
Level 11
Level 11
You can try using ifAdminStatus and ifOperStatus
