Hi there.
Resently i configure some MC20x20V cards with mac-domain 1/ 2 (one dw for tow upstreams) but the problem is when i whant see the dowsntream utilization in the snmpwalk only i see trafic in the interface downstream interface Cable6/1/0 (for example) when i espect to see the integrated dowsntream utilization, here the config of the downstream:
downstream Integrated-Cable 6/1/0 rf-channel 0 upstream 0-1
downstream Integrated-Cable 6/1/0 rf-channel 1 upstream 2-3
cable tftp-enforce
cable mtc-mode
cable shared-secret 7 110D1C1716150E01092F2C253A3631
no cable packet-cache
cable default-phy-burst 0
cable bundle 80
cable upstream max-ports 4
cable upstream bonding-group 61
upstream 0
attributes 80000000
cable upstream bonding-group 610
upstream 2
upstream 3
attributes 80000000
cable upstream 0 connector 0 shared
cable upstream 0 frequency 24000000
cable upstream 0 channel-width 3200000 3200000
cable upstream 0 power-level -4
cable upstream 0 docsis-mode atdma
cable upstream 0 minislot-size 2
cable upstream 0 range-backoff 3 6
cable upstream 0 modulation-profile 221
cable upstream 0 equalization-coefficient
no cable upstream 0 shutdown
cable upstream 1 connector 0 shared
cable upstream 1 frequency 28000000
cable upstream 1 channel-width 3200000 3200000
cable upstream 1 docsis-mode atdma
cable upstream 1 minislot-size 2
cable upstream 1 range-backoff 3 6
cable upstream 1 modulation-profile 221
cable upstream 1 equalization-coefficient
no cable upstream 1 shutdown
cable upstream 2 connector 2
cable upstream 2 frequency 32000000
cable upstream 2 channel-width 3200000 3200000
cable upstream 2 docsis-mode atdma
cable upstream 2 minislot-size 2
cable upstream 2 range-backoff 3 6
cable upstream 2 modulation-profile 221
no cable upstream 2 shutdown
cable upstream 3 connector 3
cable upstream 3 frequency 36000000
cable upstream 3 channel-width 3200000 3200000
cable upstream 3 docsis-mode atdma
cable upstream 3 minislot-size 2
cable upstream 3 range-backoff 3 6
cable upstream 3 modulation-profile 221
no cable upstream 3 shutdown
cable privacy mandatory
interface Wideband-Cable6/1/0:0
cable bundle 80
cable bonding-group-id 737
cable dynamic-bw-sharing
cable rf-channel 0 bandwidth-percent 50
cable rf-channel 1 bandwidth-percent 50
interface Integrated-Cable6/1/0:0
cable bundle 80
cable rf-bandwidth-percent 50
interface Integrated-Cable6/1/0:1
cable bundle 80
interface Integrated-Cable6/1/0:2
cable rf-bandwidth-percent 20
interface Integrated-Cable6/1/0:3
cable rf-bandwidth-percent 10
I need monitoring the rf channel 0 and 1 by snmp, anyone knows how?
Best regards.
