Monitoring session destination not showing output traffic
egr1985
I have two cisco catalyst 9300 switches with a trunk between the two. The monitoring session destination interface gig 1/0/24 is not displaying any output traffic. below are the configurations i have in place:
Type : Local Session
Source VLANs :
Both : 20
Destination Ports : Gi1/0/24
Encapsulation : Native
Ingress : Enabled, default VLAN = 1
Ingress encap : DOT1Q
PCN247#show interface gig 1/0/24
GigabitEthernet1/0/24 is up, line protocol is down (monitoring)
Hardware is Gigabit Ethernet, address is 482e.724d.6898 (bia 482e.724d.6898)
Description: monitor session back to Nozomi port #1
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
Output 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
julian.bendix
Level 4
Level 4
Hey!
Are you sure that there is traffic on VLAN 20?
Can you share the running config of the destination port, the SPAN config and the output of "sh mac add vl 20"?
BR
Jules
