Multicast dropped and invalid packets
david.bradley
I've read all I can on the cisco.com site and not found a good explanation of dropped and invalid IGMP packets.
This output is displayed from a cat os 'show igmp statistics', dropped packets and also invalid packets.
What are these and what can cause them??
Hello David,
do you happen to see entries in your logs such as:
%MCAST-6-IGMP_PKT_DROPPED: IGMP: IGMP Queue full (high packet rate/CPU busy), dropped [dec] packet(s) in last 5 minutes
According to CCO, ´this message indicates that the IGMP packet queue is not able to accommodate additional packets. Any additional packets will be dropped without processing.
Recommended Action: Reduce the IGMP packet rate to prevent packets from being dropped´
You might want to try and enable IGMP Snooping (set igmp enable) on your switch, in order to reduce the number of IGMP packets sent...
GP
Yes I've seen that syslog entry, so that explains the drops. I'm still not sure about the invalid packets, perhaps this is also a symptom too.
I think IGMP snoop is enabled but I will check.
Dave
