11-03-2015 11:52 AM - edited 03-03-2019 08:02 AM
I have a simple config (posted below) with 2 VLANs. I am dealing with bad software that I can not tell it what IP address to output on. I have 4 multicast IPs that will broadcast on one or the other VLANs. I want these 4 multicast address to be on both VLANs 100 and 300. Any help please
version 12.2
no service pad
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 100,300
interface FastEthernet1
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
switchport access vlan 100
switchport mode access
no cdp enable
interface GigabitEthernet1/2
no cdp enable
interface GigabitEthernet1/3
no cdp enable
interface GigabitEthernet1/4
no cdp enable
interface GigabitEthernet1/5
no cdp enable
interface GigabitEthernet1/6
no cdp enable
interface GigabitEthernet1/7
no cdp enable
interface GigabitEthernet1/8
no cdp enable
interface GigabitEthernet1/9
no cdp enable
interface GigabitEthernet1/10
no cdp enable
interface GigabitEthernet1/11
no cdp enable
interface GigabitEthernet1/12
no cdp enable
interface GigabitEthernet1/13
no cdp enable
interface GigabitEthernet1/14
no cdp enable
interface GigabitEthernet1/15
no cdp enable
interface GigabitEthernet1/16
no cdp enable
interface GigabitEthernet1/17
no cdp enable
interface GigabitEthernet1/18
no cdp enable
interface GigabitEthernet1/19
no cdp enable
interface GigabitEthernet1/20
no cdp enable
interface GigabitEthernet1/21
no cdp enable
interface GigabitEthernet1/22
no cdp enable
interface GigabitEthernet1/23
no cdp enable
interface GigabitEthernet1/24
no cdp enable
interface GigabitEthernet1/25
no cdp enable
interface GigabitEthernet1/26
no cdp enable
interface GigabitEthernet1/27
no cdp enable
interface GigabitEthernet1/28
no cdp enable
interface GigabitEthernet1/29
no cdp enable
interface GigabitEthernet1/30
no cdp enable
interface GigabitEthernet1/31
no cdp enable
interface GigabitEthernet1/32
no cdp enable
interface GigabitEthernet1/33
switchport access vlan 300
no cdp enable
interface GigabitEthernet1/34
no cdp enable
interface GigabitEthernet1/35
no cdp enable
interface GigabitEthernet1/36
no cdp enable
interface GigabitEthernet1/37
no cdp enable
interface GigabitEthernet1/38
no cdp enable
interface GigabitEthernet1/39
no cdp enable
interface GigabitEthernet1/40
no cdp enable
interface GigabitEthernet1/41
no cdp enable
interface GigabitEthernet1/42
no cdp enable
interface GigabitEthernet1/43
no cdp enable
interface GigabitEthernet1/44
no cdp enable
interface GigabitEthernet1/45
no cdp enable
interface GigabitEthernet1/46
no cdp enable
interface GigabitEthernet1/47
no cdp enable
interface GigabitEthernet1/48
no cdp enable
interface TenGigabitEthernet1/49
shutdown
interface TenGigabitEthernet1/50
shutdown
interface Vlan1
no ip address
ip http server
control-plane
line con 0
stopbits 1
line vty 0 4
login
end
11-16-2015 07:25 PM
Where is the routing for vlan 100 and vlan 300? You need to enable multicast routing on the router for the two vlans if you want to pass multicast between the two vlans.
John
