04-25-2005 12:34 PM - edited 03-02-2019 10:34 PM
I am setting 1841 at my site and have a NAT issue.
Basically I need i have a setup with 3 public IP's given by my ISP and am using 192.168.1.xxx as my private.
Public IP on FE0/0 and Private on FE0/1
I can go out to internet fine on one of the IP's however I need to setup a mail server on one of the private IP's and need as second public IP to be redirected to this private IP
I am using
ip nat inside source static 192.168.1.10 public-ip
i can ping the public IP from the internal interface however I cannot ping it from outside.
My undesrtanding is that the second public IP will come up automatically when I bring up the ip nat inside command.
any insite. I can send you my full config if you like
thanks,
AK
04-25-2005 01:31 PM
If you just want to permit mail, you can simply do this,
ip nat inside source static tcp 192.168.1.10 25 pblic-ip 25
Do yo uhave any other ACLs in place on the fast E interfaces ? What is the subnet mask of the public IP given to you - /29 ? (255.255.255.248)
04-25-2005 03:37 PM
The netmask is 255.255.255.0
here are acl's in place
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 permit any
access-list 100 permit udp host 192.168.1.10 eq domain any
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.1 eq telnet
access-list 100 deny tcp any host 192.168.1.1 eq telnet
access-list 100 permit ip any any
access-list 101 permit ip 0.0.0.0 0.0.0.255 any
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 0.0.0.0 0.0.0.255 any
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 103 permit tcp 0.0.0.0 0.0.0.255 host 216.240.xxx.xxx eq telnet
thanks
04-25-2005 07:40 PM
I would like to know how these access-lists are applied, which ones are applied on what interface. A show run of your router with ip addresses (public ips) and passwords masked would help.
