Route-policy problem
mtrcek
We are having problems with policy routing after we upgraded Catalyst 6509.
Everything worked fine until we upgraded version of IOS to 12.1(22)E5.
Is there any known problem with this?
Any help would be apprechiate...
Regards, Marko
Hello Marko.
a search in the bug toolkit revelas numerous bugs...can you give a few more details on what you are running into ?
If you have sufficient CCO access, check the link below, this is the output from the bug search:
http://www.cisco.com/cgi-bin/Support/Bugtool/bugnav2.pl?swver1=&fset1=&severity1=&resultsperpage1=&target1=&train1=&swver=12.1&target=22&train=E5&mdf_label=Cisco+IOS+Releases&rneflag=1&swver2=1009&target2=1356&train2=2945&fset=%3F&keyw=policy&operato...
GP
Hi GP,
Thank you for your response. I found 2 similar problems but not exactly the same. Problem is that all packets are routed normaly (through default route) even if they are included in policy routing.
I guess that workaround is to move to another version.
Regards, Marko
