NAT Problem with 1841 IS
akalhan
I am setting 1841 at my site and have a NAT issue.
Basically I need i have a setup with 3 public IP's given by my ISP and am using 192.168.1.xxx as my private.
Public IP on FE0/0 and Private on FE0/1
I can go out to internet fine on one of the IP's however I need to setup a mail server on one of the private IP's and need as second public IP to be redirected to this private IP
I am using
ip nat inside source static 192.168.1.10 public-ip
i can ping the public IP from the internal interface however I cannot ping it from outside.
My undesrtanding is that the second public IP will come up automatically when I bring up the ip nat inside command.
any insite. I can send you my full config if you like
thanks,
AK
thisisshanky
Level 11
Level 11
If you just want to permit mail, you can simply do this,
ip nat inside source static tcp 192.168.1.10 25 pblic-ip 25
Do yo uhave any other ACLs in place on the fast E interfaces ? What is the subnet mask of the public IP given to you - /29 ? (255.255.255.248)
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
The netmask is 255.255.255.0
here are acl's in place
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 permit any
access-list 100 permit udp host 192.168.1.10 eq domain any
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.1 eq telnet
access-list 100 deny tcp any host 192.168.1.1 eq telnet
access-list 100 permit ip any any
access-list 101 permit ip 0.0.0.0 0.0.0.255 any
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 0.0.0.0 0.0.0.255 any
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 103 permit tcp 0.0.0.0 0.0.0.255 host 216.240.xxx.xxx eq telnet
thanks
I would like to know how these access-lists are applied, which ones are applied on what interface. A show run of your router with ip addresses (public ips) and passwords masked would help.
Sankar Nair
