07-22-2003 03:35 PM - edited 03-02-2019 09:02 AM
I have this configuration :
interface FastEthernet0/0
no ip address
ip route-cache flow
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation isl 1
ip address 10.1.1.1 255.255.0.0
ip nat inside
ip policy route-map INTERNA
interface FastEthernet0/0.2
encapsulation isl 2
ip address 200.33.166.129 255.255.255.128
ip policy route-map SERVER
interface Serial0/0
bandwidth 128
ip unnumbered FastEthernet0/0.2
hold-queue 200 in
hold-queue 200 out
interface FastEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Serial0/1
no ip address
shutdown
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username cttmexico password 7 xxxxxxx
ip nat translation timeout never
ip nat translation tcp-timeout never
ip nat translation udp-timeout never
ip nat translation syn-timeout never
ip nat translation icmp-timeout never
ip nat translation port-timeout tcp 80 never
ip nat translation max-entries 21474836
ip nat inside source list 1 interface Dialer1 overload
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Serial0/0 200
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 10 permit 10.1.0.4
access-list 10 permit 216.239.53.99
access-list 101 deny ip 200.33.166.128 0.0.0.127 10.1.0.0 0.0.255.255
access-list 101 permit ip any any
access-list 115 deny ip 10.1.0.0 0.0.255.255 200.33.166.128 0.0.0.127
access-list 115 permit ip any any
access-list 125 deny ip 10.0.0.0 0.255.255.255 200.33.166.128 0.0.0.127
access-list 125 permit ip any any
dialer-list 1 protocol ip permit
route-map SERVER permit 10
match ip address 101
set interface Serial0/0
route-map INTERNA permit 10
match ip address 125
set interface Dialer1
every thing was working fine until yesterday, now for example i cant browse www.google.com, but, and here is the funny stuff, i can ping www.google.com ?
is this a IOS bug problem?
what ios do you think will solve the problem?
my config is not good?
07-23-2003 06:36 AM
You are not timing out any translations. Is it possible that enough conversations were dropped that you are near the configured limit? See how many translations are active.
07-23-2003 06:48 AM
If you put the IP address for Google in your web browser can you open it. Do you run a firewall?
07-23-2003 11:17 AM
I am not running any firewall ... i have a direct conecction to internet
