Need help Cisco Roter 800A
admin_2
Level 3
Level 3
hello,
This morning i was not able to ping the router on a public IP, on running show running-config i get the following
Router#show running-config
Building configuration...
Current configuration : 610 bytes
version 12.2
no service pad
hostname Router
logging queue-limit 100
ip subnet-zero
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip classless
no ip http server
no ip http secure-server
line con 0
no modem enable
stopbits 1
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
does this config show that i have no ip address assign to ethernet0?
Many thanks in advance
Simon Whale
Harold Ritter
This pretty much the default configuration for the router. No IP addresses. Two things:
- Do a "sh start" to see if NVRAM contains the configuration you want.
- make sure your configuration register is set to 0x2102. This can be seen on the last line of output from "sh ver" command. If it is not do the following:
config memory, which will load the config from NVRAM and then
config t
config-register 0x2102
Hope this helps,
thank you, it worked from the commands i could see that the config was still there and change the config-register bits to 0x2102 it then worked.
Simon
jcsm1th
Simon,
It appears from the config, that not only do you not have an IP address configured on the router, but it is shutdown as well. The same is true for the ATM interface.
Without knowing the exact circumstances around this problem, it could be something as simple as forgetting to write the config after you set it up (changed it). Then at some point, the router was reset or lost power and reloaded the start-up config.
Just a guess.
js
