Need help connecting to console of Cisco 2600 series routers
adama.yocam
I bought some hardware and created my own lab to help prepare for the CCNA.  I only have one machine with a serial port and whenever I try to connect to a router (I've tried multiple purchased from different sources) nothing happens on the screen.  If I wait for a couple of seconds and hit enter I get the response shown on the screen in the screenshot I have inserted.  If this image is too small I have also attached.
The question looks like it has already asked me this but I am unable to see it.  Shouldn't I see some information when I attempt to connect, some acknowledgement that I have connected?  I have tried using both hyperterminal anbd PuTTy.  My settings are
8
none
Off
and I have tried both of my COM ports.  Any suggestions?  Do I need to purchase an RJ-45 to USB cable and try on a different machine?  Currently I am using the blue serial-RJ-45
Thank you for your time
Sandeep Choudhary
HiAdama,
use console cable
use setting
9600
8
none
hardware
http://www.bitsbyjohn.com/2011/05/how-to-connect-a-router-to-a-computer/
and then try
Reagrds
Sandeep
Sandeep Choudhary
HiAdama,
use console cable
use setting
9600
8
none
hardware
and then try
Reagrds
Sandeep
