Need Help Setting Up WAN in Cisco Packet Tracer
nrodd69
M02@rt37
Hello @nrodd69
The serial WAN link between building A and C is down! Since both ends are currently down/down, there’s a possible clocking issue, not just an IP config issue... Double check if only one side provide the clock signal. Only the DCE end needs to provide clocking with the clock rate command.
Best regards
Enes Simnica
hello @nrodd69 that is a sick lab, i love it/ Alright, It looks like ur WAN link between Admin/Building A and Building C is down because the serial interfaces on both ends (Building A S0/0/1 and Building C S0/0/0) are showing down/down. This usually means there’s either no proper clocking on the DCE side, incorrect encapsulation, or the serial connection isn’t actually linked in Packet Tracer.
I will troubleshoot ur topology after 2 or 3 hours, and will paste here the solution...
Till then, grab some coffee, and enjoy....
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Oh sorry, I got it re configured. Ill send my updated file here. I think I am having a problem with the Static IP from Admin to Building C (SABM Building on the updated file).
Hello again, I already checked the clocking and confirmed that the Building C Serial0/0/0 is DCE and has a clock rate set (I even tried setting clock rate 64000 manually).
Physically, the Serial 0/0/1 on Admin is connected to cloud port 0, and Serial 0/0/0 on SABM is connected to cloud port 1. The cloud device is powered on.
But the interface rotocols on both side still show as down.
Could his be a problem with how im connecting the cloud device? or is there something else I should check?
Thanks in advance for any tips!
M02@rt37
Hello @nrodd69
Best regards
