Need Help!!, Urgent.
wfahme
I need to configure 801 router on leased Line ISDN. Can any one give me the link on cisco website where the commands and configurations examples are posted
best regards
lee.reade
Thanks for your comments and Links.
the link provide configuration of IDSL.
Is Dedicated ISDN and IDSL are same.?>
I am using 801 for Dedicated ISDN, will the link configuration be applicable in 801.?
regards
jmia
Level 7
Level 7
Hi Walid -
Q. Are you setting up site-to-site ISDN connection? If so send me your e-mail address and I'll post you the information that you require urgently off-line (not on this forum)
My e-mail is above.
Thanks -
