Need help with access-list
asifchoudhury
I've configured RIPv2 between R5, R4 and R3.
R5-E0<---------------->R4-E0<--------------->R3-E0
R4 is getting 8 routes (network 189.160.1.0 to 189.160.8.0 ) from R5 and advertising these 8 routes to R3 as a RIP routes. What I am try to do is that instead of R4 sending 8 routes to R3, I am trying to configure R4 so that R4 will send 189.160.0.0/16 only routes to R3. I do not want to use summary command to do this. Below is my config...but it does not work...R3 still sees 8 routes learned from R4. Please tell me what is wrong in my config.
R4#
int E0/0
Ip address 180.120.1.1 255.255.255.0
router rip
version 2
network 180.120.0.0
network 189.160.0.0
distribute-list prefix R3 out Ethernet0/0
no auto-summary
ip prefix-list R3 seq 5 permit 189.160.0.0/16
R3#
int E0/0
Ip address 180.120.1.2 255.255.255.0
router rip
version 2
passive-interface default
no passive-interface Ethernet0/0
network 180.120.0.0
no auto-summary
R3# sh ip route
R 189.160.1.0 [120/1] via 180.120.1.1, 00:00:01, Ethernet0/0
R 189.160.2.0 [120/2] via 180.120.1.1, 00:00:01, Ethernet0/0
R 189.160.3.0 [120/1] via 180.120.1.1, 00:00:01, Ethernet0/0
R 189.160.4.0 [120/2] via 180.120.1.1, 00:00:01, Ethernet0/0
R 189.160.5.0 [120/2] via 180.120.1.1, 00:00:01, Ethernet0/0
R 189.160.6.0 [120/2] via 180.120.1.1, 00:00:01, Ethernet0/0
R 189.160.7.0 [120/2] via 180.120.1.1, 00:00:01, Ethernet0/0
R 189.160.8.0 [120/2] via 180.120.1.1, 00:00:01, Ethernet0/0
attrgautam
Level 5
Level 5
AFAIK distribute-list will not summarise it will only restrict routes so only way to get summary routes would be to do an auto-summary.
in addition to Gautam's post, you could also redistribute a static route for the 189.160.0.0/16 into RIP. Either way, you first need the 189.160.0.0/16 route in the RIP database of R4 before you can do anything with it. Your prefix list needs to deny all prefixes for that network with a mask greater than 16.
So basically your configuration options on R4 are:
router rip
version 2
network 180.120.0.0
network 189.160.0.0
-->auto-summary
ip prefix-list R3 seq 5 deny 189.160.0.0/17 le 32
or
router rip
version 2
--> redistribute static
network 180.120.0.0
network 189.160.0.0
auto-summary
-->ip route 189.160.0.0 255.255.0.0 Ethernet0/0
HTH,
GP
