Netflow Issue on 7606-s
MyOwn1234
I have one 7606 running Version 12.2(33r)SRD6. We are trying to poll netflow for our solarwinds software. Solar wind is only able to see MSFC entries (telnet, snmp and ssh etc), PFC entries are not being shown.
Our configurations are as following...
ip flow-egress input-interface
ip flow-cache timeout active 1
mls flow ip interface-full
no mls flow ipv6
mls nde sender version 5
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination x.x.x.x 2055
interface GigabitEthernet1/1
bandwidth 400000
ip address x.x.x.x x.x.x.x
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
service-policy output TR-OUT
We have provided "ip route-cache flow" on interface g1/1 and in show run / show run all this command is not appearing.
We are getting following out put
7606#  sh ip cache flow
MSFC:
IP packet size distribution (580854 total packets):
   1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
   .000 .066 .401 .001 .077 .026 .110 .017 .029 .000 .000 .002 .000 .021 .196
    512  544  576 1024 1536 2048 2560 3072 3584 4096 4608
   .046 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
  2 active, 4094 inactive, 165962 added
  2747752 ager polls, 0 flow alloc failures
  Active flows timeout in 1 minutes
  Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 34056 bytes
  2 active, 1022 inactive, 165962 added, 165962 added to flow
  0 alloc failures, 0 force free
  1 chunk, 3 chunks added
  last clearing of statistics never
Protocol         Total    Flows   Packets Bytes  Packets Active(Sec) Idle(Sec)
--------         Flows     /Sec     /Flow  /Pkt     /Sec     /Flow     /Flow
TCP-Telnet           1      0.0         1    40      0.0       0.0      16.2
TCP-FTP              1      0.0         1    40      0.0       0.0      16.2
TCP-FTPD             1      0.0         1    40      0.0       0.0      16.2
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP  Pkts
TCP-WWW              1      0.0         1    40      0.0       0.0      15.9
TCP-SMTP             1      0.0         1    40      0.0       0.0      15.2
TCP-X                1      0.0         1    40      0.0       0.0      15.7
TCP-BGP              1      0.0         1    40      0.0       0.0      15.5
TCP-NNTP             1      0.0         1    40      0.0       0.0      15.7
TCP-other         4176      0.0         5    57      0.0       1.8       7.7
UDP-NTP          29789      0.0         1    76      0.0       0.0      15.5
UDP-other        67521      0.0         6   254      0.1       1.1      15.4
ICMP             64466      0.0         1    72      0.0       0.6      15.4
Total:          165960      0.0         3   215      0.1       0.7      15.3
Gi1/1         x.x.x.x         Local         x.x.x.x         06 0B72 0016    79
Gi1/1         x.x.x.x         Local         x.x.x.x         06 0031 D687     5
PFC:
Displaying Hardware entries in Module 5
SrcIf            SrcIPaddress          DstIPaddress      Pr       SrcP      DstP      Pkts
--               0.0.0.0               0.0.0.0           0        0         0         2773354
show module 1
7606#sh module 1
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  588d.097c.5f18 to 588d.097c.5f2f   5.0   12.2(18r)S1  12.2(33)SRE6 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC           4.1    Ok
Mod  Online Diag Status
  1  Pass
show module 5
7606#show module 5
  5    5  Route Switch Processor 720 10GE (Activ RSP720-3C-10GE
  5  68ef.bdd3.36ac to 68ef.bdd3.36b3   1.0   12.2(33r)SRD 12.2(33)SRE6 Ok
  5  Policy Feature Card 3       7600-PFC3C-10GE        1.1    Ok
  5  C7600 MSFC4 Daughterboard   7600-MSFC4             2.2    Ok
  5  Pass
Any help will be highly appreciated...
Best Regards,
RICK SCHROEDER
Check out this document, which states that 7600's don't support Netflow egress:
http://www.cisco.com/c/en/us/td/docs/routers/7600/ios/15S/configuration/guide/7600_15_0s_book/nde.html
R.
