Network Design of Big Internet Cafe using Packet Tracer
Can someone help me with the network design of a big internet cafe that has these 3 things below (see picture below) and with an IP configuration? 15 computers or 10 will do.
attached a design that should get you started (saved in PT version 8)...
Hello
Not with PT as it basically featureless and I personally wouldn’t be confident enough on its output for proof of concept, Sure you can create "a" network as already suggested however for a proper design you need to understand the hardware/software you would be running, Will the users be wired or wifi connected or both, The usage of their own I0T devices or devices you would be supplying and all the security concerns surrounding the above..
Suggest you read cisco best practices for a campus LAN/Wireless design - Here
Kind Regards
Paul
