Network traffic management
dmalamba
exchange server 5.5. I have implemented NAT
and access-list to permit mail through the
NAT interface. What stratles me is that the
64 k line seems to be at peak use all the time
and I dont believe this is the mail traffic
which is causing this. How can I check traffic typeS
passing through this interface and their port numbers
so i can block them? i.e only accept pop3 and smtp and probably www.
spremkumar
Level 9
Level 9
As already mentioned u can enable NetFlow using ip route-cache command under u r lan interface and chek to which ip/port most of the packets r destined .
regds
prem
shery.zimmerman
If you have a laptop and open switch port, you can also download ethereal - shareware protocol analyzer, which can "look" at traffic via spanport/port mon
