Networking Question
stonnet72
Site A
- end users
- 3COM Switch (Gig)
- Cisco 3560 Switch
- SPF/GBics w/Fiber connection (to Site B)
- this switch has an IP address on port 1 (a VLAN address I assigned to it for management purposes)
- Fiber switch is connected via ethernet cable to 3COM switch
Site B
- end users
- 3COM Switch (Gig)
- Cisco 3560 Switch
- SPF/GBics w/Fiber connection (to Site A)
- originally connected to the 3COM switch via ehternet cable until I recently unplugged it
Site A address is 172.16.140.x
Site A address is 172.16.150.x
An end user came up on the .140.x side and requested and recieved an .150.x address, before I unplugged Site B's ethernet cable. Site A does not have a local DHCP server. It has a DHCP relay agent which is sent through a router which forwards request to DHCP server in Site B and then recieves IP address respective of the network its on.
However it recieved an address from 150.x scope (via the fiber connection I believe).
Can anyone explain to me why this happen and how do I rectify? I believe that if I build a DHCP server local it should resolve the issue. I also believe that I may have to enter in some routing parameters on the 3560 Fiber switch.
I appreciate your help with this. Thanks!
5 Replies 5
Roberto Salazar
Level 8
Level 8
There are some thing you need to clear up or give more information:
1. are the 3560 doing any kinf of L3 services?
2. how are the two 3560 connected? via trunk? access port?
3. Site you said should be on 172.16.140.x and you also said that that same site shoudl be on 172.16.150.x. Which is which?
4. What vlans are the users in site A in?
5. Waht vlans are the users in site B in?
Can you post the following for both 3560:
show vlan
show int trunk
show cdr neigh detail
show ip route
show run
1. 3560 are not performing any L3 functions
2. 3560 are connected via fiber (bldg to bldg)
- they are plugged in to GBIC ports on switch
- I assigned port 1 on switch an IP address and by default it becomes VLAN1
3. Site A = 172.16.140.x
Site B = 172.16.150.x
(sorry about that)
4. Users are not in a VLAN per se I just assigned an IP address to port 1 (def VLAN port) for remote management purposes. I am thinking that I shouled have assigned a different port though right?
5. Same answer as number 4.
3560 show commands are attached in text document.
The users are supposed to be in different subnets but they are in the same vlan. therefore, when a host in site A boot up and send a DHCP request, that request is forwarded to subnet in 172.16.150.x which is why they are getting address on that range. I would assume and guess that the router that is supposed to be forwarding the bootp from this hosts are attached to switch B and in vlan 1 as well. You will need to trunk the switches and segment them in different vlans. The router will need to be trunked as well and subinterfaces for these two subnets/vlans.
Please rate helpful posts.
That makes alot of sense. All of the aforementioned. Thank you very much. You would happen to have or know of a template config file that I may be able to get some ideas from as to how I need to configure my switches and router do you?
Thank you again for your help.
I don't have a link with template that is specific to your requirement but you can try the following:
Switch A:
interface fa 0/1
host A in 172.16.140.x
switchport access vlan 1
interface gig x/1
port connecting to switch B
switchport mode trunk
interface vlan 1
mgmt interface for the sole purpose of managing the switch A
ip address 172.16.140.x 255.255.255.0
Switch B:
interface fa 0/1
host in subnet 172.16.150.x
switchport access vlan 2
interface fa 0/1
interface connecting to the router doing inter-vlan routing for subnet 172.16.140.x and 172.16.150.x
interface gig x/1
port connecting to switch A
swithcport mode trunk
interface vlan 1
mgmt interface for the sole purpose of managing the switch B
ip address 172.16.140.x+n 255.255.255.0
So, the above shows configuration for the hosts ports, ports connecting the two switches and the port connecting to the external router, assuming it is connected on switch B.
On the router, it would look like:
interface fa x/x.x
encapsulation dot1q 1 native
ip helper-address 172.16.150.x
interface fax/x.x+1
encapsulation dot1q 2
ip address 172.16.150.x 255.255.255.0
For more info on external router doing inter-vlan routing, the switches might be of different platform but the concept remains the same and shoudl apply to your situation:
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_configuration_example09186a00800949fd.shtml
