(New to packet tracer) switch login problems
dunkmlh
after configuring a password for the switch/router, I am unable to enter the password as it won't even display letters (when typing)  onto the Command Line Interface. (I'm new to packet tracer so If it's really obvious what I did wrong, that's why)
M02@rt37
Hello @dunkmlh
This behavior is normal and expected when working with passwords on Cisco switches and routers in Packet Tracer or the real world.  When you are prompted to enter a password, nothing is displayed...This is a security feature designed to ensure that someone looking at your screen cannot guess the length of the password.
So, even though nothing is displayed, type your password as you configured it and press ENTER.
Best regards
5 Replies 5
dunkmlh
Cl_NetworkBuild_AE_Sk3of3_Appx_BranchTF (1)1.pkt this is the link to the packet tracer file
Blue_Bird
Hello dunkmlh,
While you enter the password...it (letters) won't appear on the screen. Still you have to type correct password and press enter. if you type correct password, then you will be logged in to the switch. This is the default behaviour as part of security.
Best regards
******* If This Helps, Please Rate *******
M02@rt37
Hello @dunkmlh
Best regards
ohh ok, thank you so much this is very helpful!!!
randyrobe
I have also had a similar problem with this, but I don't believe it's the password itself in my case. After the switch automatically Loggs out after a few minutes of non-use.  I am unable to log back in again using the simple secret of ccna, no caps. The caps lock is not on, but it will no longer accept the password. This happens frequently on Routers and Switches in simple network simulations.
