Not Advertising Additional IP Block
deocanave
Hi Sir/Ma'am,
Hope someone can help me... My problem is that I added new ip block to my bgp to advertise. I have to cisco routers by the way... Both have same configuration but the other one is not advertising my newly added ip block...
I did use "prefix list" and "suppress-map" on my config...
if you need my config please tell me should i put here... Thank you in advance
I do see
Implicit Withdraw:             12
only thing i do see from your configuration missing is for Route-map
match list to be updated as below
ip prefix-list RadiusPathPrepend seq 150 permit 43.247.6.0/24
ip prefix-list RadiusPathPrepend seq 200 permit 43.247.7.0/24
ip prefix-list RadiusPathPrepend seq 250 permit 43.247.8.0/24
ip prefix-list RadiusPathPrepend seq 300 permit 43.247.9.0/24
Kindly update it should work for you now
Sandy
20 Replies 20
Richard Burts
My first question is whether there is an entry in your ip routing table that matches the new block that you ask BGP to advertise. If the answer to this is yes then I ask that you post the BGP configuration and also to post the output of show ip route from the router.
Rick
Rick
Hi Richard,
Here's the config on both router... I just changed some value to X for some reason...
Thanks...
router ospf 1903
 log-adjacency-changes
 redistribute connected subnets
 redistribute static subnets route-map Fiber-Null
 network 103.x.x.x 0.0.0.15 area 0
 network 103.x.x.x 0.0.0.31 area 0
 default-information originate always metric 10
router bgp 593xx
 no bgp fast-external-fallover
 no bgp log-neighbor-changes
 bgp maxas-limit 50
 neighbor Fiber-internal peer-group
 neighbor Fiber-internal remote-as 593xx
 neighbor Fiber-internal description Fiber internal BGP peers
 neighbor Fiber-internal password 7 121F441541190F5427
 neighbor Fiber-internal update-source Loopback0
 neighbor 103.x.x.x remote-as 55821
 neighbor 103.x.x.x description Y
 neighbor 103.x.x.x version 4
 neighbor 103.x.x.x peer-group Fiber-internal
 neighbor 103.x.x.x description IBGP-Fiber-NPEG-2
 neighbor 103.x.x.x remote-as 593xx
 neighbor 103.x.x.x description ZStaff
 neighbor 121.x.x.x33 remote-as 17639
 neighbor 121.x.x.x33 description X
 neighbor 121.x.x.x33 version 4
 address-family ipv4
 neighbor 103.x.x.x activate
 neighbor 103.x.x.x soft-reconfiguration inbound
 neighbor 103.x.x.x prefix-list FiberSpecific-Y out
 neighbor 103.x.x.x route-map YLocalPref in
 neighbor 103.x.x.x route-map YPathPrepend out
 neighbor 103.x.x.x filter-list 55 in
 neighbor 103.x.x.x filter-list 10 out
 neighbor 103.x.x.x send-community
 neighbor 103.x.x.x default-originate
 neighbor 103.x.x.x prefix-list ZStaff-prefix in
 neighbor 103.x.x.x route-map ZStaffLocalPref in
 neighbor 103.x.x.x maximum-prefix 5
 neighbor 103.x.x.x filter-list 80 out
 neighbor 121.x.x.x33 activate
 neighbor 121.x.x.x33 soft-reconfiguration inbound
 neighbor 121.x.x.x33 prefix-list FiberSpecific-X out
 neighbor 121.x.x.x33 route-map XLocalPref in
 neighbor 121.x.x.x33 route-map XPathPrepend out
 neighbor 121.x.x.x33 filter-list 50 in
 neighbor 121.x.x.x33 filter-list 10 out
 no auto-summary
no synchronization
 network 43.24x.x.x mask 255.255.252.0
 network 43.24x.x.x mask 255.255.255.0
 network 103.x.x.x mask 255.255.255.0
 aggregate-address 43.24x.x.x 255.255.252.0 suppress-map SuppressMap43.24x.x.x
 aggregate-address 103.x.x.x 255.255.252.0 suppress-map SuppressMap103.x.x.x
 exit-address-family
ip classless
ip route 43.24x.x.x 255.255.252.0 Null0 tag 777
ip route 43.24x.x.x 255.255.255.0 Null0 tag 777
ip route 103.x.x.x 255.255.255.0 Null0 tag 777
ip route 103.x.x.x 255.255.255.240 103.2x.x.x
no ip http server
ip as-path access-list 10 permit ^$
ip as-path access-list 10 permit ^(593xx_)+$
ip as-path access-list 50 permit .*
ip as-path access-list 51 permit ^17639_[0-9]*$
ip as-path access-list 55 permit .*
ip as-path access-list 56 permit ^55821_[0-9]*$
ip as-path access-list 80 permit ^$
ip prefix-list AllowSpecific-103.x.x.x description allow /22
ip prefix-list AllowSpecific-103.x.x.x seq 10 deny 103.x.x.x/24
ip prefix-list AllowSpecific-103.x.x.x seq 15 deny 103.x.x.x/24
ip prefix-list AllowSpecific-103.x.x.x seq 20 deny 103.x.x.x/24
ip prefix-list AllowSpecific-103.x.x.x seq 25 deny 103.x.x.x/24
ip prefix-list AllowSpecific-103.x.x.x seq 100 permit 0.0.0.0/0 le 32
ip prefix-list AllowSpecific-43.24x.x.x description allow /22
ip prefix-list AllowSpecific-43.24x.x.x seq 10 deny 43.24x.x.x/24
ip prefix-list AllowSpecific-43.24x.x.x seq 15 deny 43.24x.x.x/24
ip prefix-list AllowSpecific-43.24x.x.x seq 20 deny 43.24x.x.x/24
ip prefix-list AllowSpecific-43.24x.x.x seq 25 deny 43.24x.x.x/24
ip prefix-list AllowSpecific-43.24x.x.x seq 100 permit 0.0.0.0/0 le 32
ip prefix-list XPathPrepend description yun na
ip prefix-list XPathPrepend seq 10 permit 103.x.x.x/24
ip prefix-list XPathPrepend seq 20 permit 103.x.x.x/24
ip prefix-list XPathPrepend seq 30 permit 103.x.x.x/24
ip prefix-list XPathPrepend seq 100 deny 0.0.0.0/0 le 32
ip prefix-list Fiber-Null description list of pull up routes
ip prefix-list Fiber-Null seq 5 deny 103.x.x.x/22
ip prefix-list Fiber-Null seq 6 deny 43.24x.x.x/22
ip prefix-list Fiber-Null seq 10 permit 0.0.0.0/0 le 32
ip prefix-list FiberSpecific-X description Prefix Advertise to X
ip prefix-list FiberSpecific-X seq 100 permit 0.0.0.0/0 le 32
ip prefix-list FiberSpecific-Y seq 10 deny 103.x.x.x/24
ip prefix-list FiberSpecific-Y seq 20 deny 103.x.x.x/24
ip prefix-list FiberSpecific-Y seq 30 deny 103.x.x.x/24
ip prefix-list FiberSpecific-Y seq 40 deny 103.x.x.x/24
ip prefix-list FiberSpecific-Y seq 100 permit 0.0.0.0/0 le 32
ip prefix-list ZStaff-prefix description ZStaff prefixes
ip prefix-list ZStaff-prefix seq 5 permit 103.x.x.x/24
ip prefix-list ZStaff-prefix seq 100 deny 0.0.0.0/0 le 32
access-list 99 permit 103.x.x.x
access-list 99 permit 103.x.x.x 0.0.0.255
access-list 110 permit ip host 61.9.0.41 any
access-list 110 deny   ip any any
route-map ZStaffLocalPref permit 10
 match ip address prefix-list ZStaff-prefix
 set local-preference 210
route-map ZStaffLocalPref permit 20
route-map SuppressMap43.24x.x.x permit 10
 match ip address prefix-list AllowSpecific-43.24x.x.x
route-map XPathPrepend permit 10
 match ip address prefix-list XPathPrepend
 set as-path prepend 59322
route-map XPathPrepend permit 20
route-map Fiber-Null deny 10
 match tag 777
route-map Fiber-Null permit 20
route-map YLocalPref permit 10
 match as-path 56
 set local-preference 202
route-map YLocalPref permit 20
route-map XLocalPref permit 10
 match as-path 51
route-map XLocalPref permit 20
route-map SuppressMap103.x.x.x permit 10
 match ip address prefix-list AllowSpecific-103.x.x.x
sh ip bgp neighbors 103.x.x.209 advertised-routes
BGP table version is 267057656, local router ID is 103.x.x.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 103.x.x.0/24  0.0.0.0                  0         32768 i
The 103.x.x.0/24 block is advertising but not the 43.24x.x.x/24 block
The information that you provide here is not useful to understand the problem. Your most recent post seems to reference a particular neighbor with whom you have this problem. But your conversion of the configuration details to 103.x.x.x prevents me from knowing which of the neighbors in the config is the one that has the problem.
Rick
Rick
Sorry if I did change the ip address to x.x.x for security purpose... The scenario was:
I have bgp peering with AS55821 and successfully advertising the ip block 103.225.x.x/22 . All was working properly. And then we want to add another ip block which is 43.247.x.x to the same bgp peering (AS55821). The configuration of both ip blocks are the same but it's not working...
Here's my actual configuration:
router ospf 1903
 network 103.225.6.0 0.0.0.15 area 0
 network 103.225.7.0 0.0.0.31 area 0
router bgp 5922
 bgp maxas-limit 50
 neighbor Fiber-internal remote-as 5922
 neighbor Fiber-internal password 7 03021A09551D221C43
 neighbor 103.16.17.209 remote-as 55821
 neighbor 103.16.17.209 description Radius
 neighbor 103.16.17.209 version 4
 neighbor 103.225.6.1 peer-group Fiber-internal
 neighbor 103.225.6.1 description IBGP-Fiber-NPEG-1
 neighbor 121.58.19.33 remote-as 17639
 neighbor 121.58.19.33 description Comclark
 neighbor 121.58.19.33 version 4
 address-family ipv4
 neighbor 103.16.17.209 activate
 neighbor 103.16.17.209 soft-reconfiguration inbound
 neighbor 103.16.17.209 prefix-list FiberSpecific-Radius out
 neighbor 103.16.17.209 route-map RadiusLocalPref in
 neighbor 103.16.17.209 route-map RadiusPathPrepend out
 neighbor 103.16.17.209 filter-list 55 in
 neighbor 103.16.17.209 filter-list 10 out
 neighbor 103.225.6.1 activate
 neighbor 121.58.19.33 activate
 neighbor 121.58.19.33 soft-reconfiguration inbound
 neighbor 121.58.19.33 prefix-list FiberSpecific-Comclark out
 neighbor 121.58.19.33 route-map ComclarkLocalPref in
 neighbor 121.58.19.33 route-map ComclarkPathPrepend out
 neighbor 121.58.19.33 filter-list 50 in
 neighbor 121.58.19.33 filter-list 10 out
 no auto-summary
 no synchronization
 network 43.247.6.0 mask 255.255.252.0
 network 43.247.6.0 mask 255.255.255.0
 network 43.247.7.0 mask 255.255.255.0
 network 43.247.8.0 mask 255.255.255.0
 network 43.247.9.0 mask 255.255.255.0
 network 103.225.6.0 mask 255.255.252.0
 network 103.225.6.0 mask 255.255.255.0
 network 103.225.7.0 mask 255.255.255.0
 network 103.225.9.0 mask 255.255.255.0
 aggregate-address 43.247.6.0 255.255.252.0 suppress-map SuppressMap43.247.6.0
 aggregate-address 103.225.6.0 255.255.252.0 suppress-map SuppressMap103.225.6.0
 exit-address-family
ip classless
ip route 43.247.6.0 255.255.252.0 Null0 tag 777
ip route 43.247.6.0 255.255.255.0 Null0 tag 777
ip route 43.247.7.0 255.255.255.0 Null0 tag 777
ip route 43.247.8.0 255.255.255.0 Null0 tag 777
ip route 43.247.9.0 255.255.255.0 Null0 tag 777
ip route 103.225.6.0 255.255.252.0 Null0 tag 777
ip route 103.225.6.0 255.255.255.0 Null0 tag 777
ip route 103.225.7.0 255.255.255.0 Null0 tag 777
ip route 103.225.9.0 255.255.255.0 Null0 tag 777
no ip http server
ip as-path access-list 10 permit ^(59334_)+$
ip as-path access-list 56 permit _4134$
ip as-path access-list 56 permit _23456$
ip as-path access-list 56 permit _3491$
ip prefix-list AllowSpecific-103.225.6.0 description allow /22
ip prefix-list AllowSpecific-103.225.6.0 seq 10 deny 103.225.6.0/24
ip prefix-list AllowSpecific-103.225.6.0 seq 15 deny 103.225.7.0/24
ip prefix-list AllowSpecific-103.225.6.0 seq 20 deny 103.225.8.0/24
ip prefix-list AllowSpecific-103.225.6.0 seq 25 deny 103.225.9.0/24
ip prefix-list AllowSpecific-103.225.6.0 seq 100 permit 0.0.0.0/0 le 32
ip prefix-list AllowSpecific-43.247.6.0 description allow /22
ip prefix-list AllowSpecific-43.247.6.0 seq 10 deny 43.247.6.0/24
ip prefix-list AllowSpecific-43.247.6.0 seq 15 deny 43.247.7.0/24
ip prefix-list AllowSpecific-43.247.6.0 seq 20 deny 43.247.8.0/24
ip prefix-list AllowSpecific-43.247.6.0 seq 25 deny 43.247.9.0/24
ip prefix-list AllowSpecific-43.247.6.0 seq 100 permit 0.0.0.0/0 le 32
ip prefix-list Fiber-Null seq 5 deny 103.225.6.0/22
ip prefix-list Fiber-Null seq 6 deny 43.247.6.0/22
ip prefix-list FiberSpecific-Comclark seq 10 deny 103.225.6.0/24
ip prefix-list FiberSpecific-Comclark seq 15 deny 103.225.7.0/24
ip prefix-list FiberSpecific-Comclark seq 20 deny 103.225.8.0/24
ip prefix-list FiberSpecific-Comclark seq 25 deny 103.225.9.0/24
ip prefix-list FiberSpecific-Comclark seq 100 permit 0.0.0.0/0 le 32
ip prefix-list FiberSpecific-Radius description Prefix Advertise to Radius
ip prefix-list FiberSpecific-Radius seq 100 permit 0.0.0.0/0 le 32
ip prefix-list RadiusPathPrepend description yun na
ip prefix-list RadiusPathPrepend seq 50 permit 103.225.9.0/24
ip prefix-list RadiusPathPrepend seq 100 deny 0.0.0.0/0 le 32
ip prefix-list RadiusPathPrepend-2 description yun na
ip prefix-list RadiusPathPrepend-2 seq 50 permit 103.225.6.0/24
ip prefix-list RadiusPathPrepend-2 seq 60 permit 103.225.7.0/24
ip prefix-list RadiusPathPrepend-2 seq 100 deny 0.0.0.0/0 le 32
access-list 99 permit 103.16.17.210
access-list 99 permit 103.225.6.0 0.0.0.255
access-list 99 permit 103.225.7.0 0.0.0.255
access-list 99 permit 103.225.8.0 0.0.0.255
access-list 99 permit 103.225.9.0 0.0.0.255
access-list 110 permit ip host 61.9.101.1 any
route-map ComclarkPthPrepend permit 10
route-map SuppressMap43.247.6.0 permit 10
 match ip address prefix-list AllowSpecific-43.247.6.0
 match tag 777
route-map RadiusPathPrepend permit 10
 match ip address prefix-list RadiusPathPrepend
route-map RadiusPathPrepend permit 20
 match ip address prefix-list RadiusPathPrepend-2
 set as-path prepend 5922
route-map RadiusLocalPref permit 10
 match as-path 56
 set local-preference 205
route-map RadiusLocalPref permit 20
route-map ComclarkLocalPref permit 10
 match as-path 51
route-map ComclarkLocalPref permit 20
route-map SuppressMap103.225.6.0 permit 10
 match ip address prefix-list AllowSpecific-103.225.6.0
Hi ,
 Can you share me following output
1) show ip ospf database
2) show ip bgp
3) show ip bgp neigbhor 103.16.17.209
4)  show ip bgp filter-list 10
5) show ip bgp rib-failure
Suspecting problem on network reach ability  for your new network statement . configure below statement without tag
Sandy
Below are the results for the following commands:
sh ip ospf database
            OSPF Router with ID (103.225.6.2) (Process ID 1903)
        Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
103.225.6.1    103.225.6.1    1363        0x8000160D 0x00F644 3
103.225.6.2    103.225.6.2    1092        0x80000026 0x00B913 2
103.225.6.3    103.225.6.3    985         0x80001609 0x0019B5 2
        Net Link States (Area 0)
103.225.7.1    103.225.6.1    1363        0x80000025 0x006C98
        Type-5 AS External Link States
Link ID         ADV Router      Age         Seq#       Checksum Tag
0.0.0.0         103.225.6.1    320         0x80001607 0x00CDDB 1903
0.0.0.0         103.225.6.2    1092        0x80001603 0x007540 1903
103.16.17.208  103.225.6.2    1092        0x80001603 0x003EEE 0
103.225.6.16   103.225.6.1    320         0x800003E4 0x0003D9 0
103.225.6.32   103.225.6.1    320         0x800003E4 0x00626A 0
103.225.6.48   103.225.6.1    320         0x800003E4 0x00C1FA 0
103.225.6.64   103.225.6.1    578         0x80000006 0x00186E 0
103.225.6.224  103.225.6.1    323         0x800003E4 0x00DA31 0
103.225.7.160  103.225.6.1    323         0x800003E4 0x00F169 0
103.225.7.208  103.225.6.1    323         0x800003E4 0x00B856 0
103.225.7.212  103.225.6.1    323         0x800003E4 0x00907A 0
103.225.7.216  103.225.6.1    323         0x800003E4 0x00689E 0
103.225.7.220  103.225.6.1    323         0x80000334 0x00A112 0
103.225.7.240  103.225.6.1    323         0x800003E4 0x005F93 0
103.225.7.252  103.225.6.1    323         0x800003E4 0x00FEE3 0
103.225.9.0    103.225.6.1    323         0x800003E4 0x0022D7 0
103.225.9.48   103.225.6.1    323         0x800004B9 0x00F3EF 0
103.225.9.240  103.225.6.1    323         0x800003E4 0x0049A7 0
121.58.194.32   103.225.6.1    323         0x800010FB 0x005D3A 0
175.158.106.56  103.225.6.2    1094        0x800001D8 0x005A0D 0
202.176.199.133 103.225.6.2    1094        0x80001374 0x00AB36 0
show ip bgp neig 103.16.17.209
BGP neighbor is 103.16.17.209,  remote AS 55821, external link
 Description: Radius
  BGP version 4, remote router ID 103.16.169.186
  BGP state = Established, up for 19:50:10
  Last read 00:00:19, hold time is 180, keepalive interval is 60 seconds
  Neighbor capabilities:
    Route refresh: advertised and received(old & new)
    Address family IPv4 Unicast: advertised and received
  Message statistics:
    InQ depth is 0
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:                8     391986
    Keepalives:          1193          2
    Route Refresh:          0          0
    Total:               1202     391989
  Default minimum time between advertisement runs is 30 seconds
 For address family: IPv4 Unicast
  BGP table version 2385077, neighbor version 2385077
  Index 2, Offset 0, Mask 0x4
  Inbound soft reconfiguration allowed
  Inbound path policy configured
  Outbound path policy configured
  Outgoing update prefix filter list is FiberSpecific-Radius
  Incoming update AS path filter list is 55
  Outgoing update AS path filter list is 10
  Route map for incoming advertisements is RadiusLocalPref
  Route map for outgoing advertisements is RadiusPathPrepend
                                 Sent       Rcvd
  Prefix activity:               ----       ----
    Prefixes Current:               3     508098 (Consumes 25423200 bytes)
    Prefixes Total:                12    1926191
    Implicit Withdraw:              9    1394168
    Explicit Withdraw:              0      23925
    Used as bestpath:             n/a     436896
    Used as multipath:            n/a          0
    Saved (soft-reconfig):        n/a      21552 (Consumes 1034496 bytes)
                                   Outbound    Inbound
  Local Policy Denied Prefixes:    --------    -------
    route-map:                           17          0
    filter-list:                     654351          0
    prefix-list                           6          0
    Suppressed duplicate:                 0     128126
    AS_PATH loop:                       n/a          7
    Bestpath from this peer:        2954215        n/a
    Suppressed due to dampening:         20        n/a
    Total:                          3608609     128133
  Number of NLRIs in the update sent: max 2, min 0
Connections established 1; dropped 0
  Last reset never
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Local host: 103.16.17.210, Local port: 179
Foreign host: 103.16.17.209, Foreign port: 13799
Enqueued packets for retransmit: 0, input: 0  mis-ordered: 0 (0 bytes)
Event Timers (current time is 0x44202F0):
Timer          Starts    Wakeups            Next
Retrans          1198          1             0x0
TimeWait            0          0             0x0
AckHold         12426       1827             0x0
SendWnd             0          0             0x0
KeepAlive           1          0             0x0
GiveUp              0          0             0x0
PmtuAger            0          0             0x0
DeadWait            0          0             0x0
iss:  786668411  snduna:  786691564  sndnxt:  786691564     sndwnd:  31628
irs: 3197216748  rcvnxt: 3227471037  rcvwnd:      16032  delrcvwnd:    352
SRTT: 300 ms, RTTO: 303 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 0 ms, maxRTT: 404 ms, ACK hold: 200 ms
Flags: passive open, nagle, gen tcbs
Datagrams (max data segment is 1460 bytes):
Rcvd: 23071 (out of order: 6), with data: 21886, total data bytes: 30254288
Sent: 22548 (retransmit: 1, fastretransmit: 0), with data: 1196, total data bytes: 23152
BGP table version is 2386911, local router ID is 103.225.6.2
s> 43.247.6.0/24   0.0.0.0                  0         32768 i
s i                 103.225.6.1             0    100      0 i
*> 43.247.6.0/22   0.0.0.0                  0         32768 i
*                   0.0.0.0                            32768 i
* i                 103.225.6.1             0    100      0 i
s> 43.247.7.0/24   0.0.0.0                  0         32768 i
s> 43.247.8.0/24   0.0.0.0                  0         32768 i
s> 43.247.9.0/24   0.0.0.0                  0         32768 i
* i103.225.6.0/24  103.225.6.1             0    100      0 i
*>                  0.0.0.0                  0         32768 i
*> 103.225.6.0/22  0.0.0.0                            32768 i
* i103.225.7.0/24  103.225.6.1             0    100      0 i
*>i103.225.8.0/24  103.225.7.218           0    210      0 59334 i
* i103.225.9.0/24  103.225.6.1             0    100      0 i
Network            Next Hop                      RIB-failure   RIB-NH Matches
Hi ,
 Remove tag from your Null 0 and try to advertise . And let me with show ip bgp
table
no ip route 43.247.6.0 255.255.252.0 Null0 tag 777
no ip route 43.247.6.0 255.255.255.0 Null0 tag 777
no ip route 43.247.7.0 255.255.255.0 Null0 tag 777
no ip route 43.247.8.0 255.255.255.0 Null0 tag 777
no ip route 43.247.9.0 255.255.255.0 Null0 tag 777
Sandy
Hi Sir,
I did remove the following tag but still nothing happens... :(
sh ip bgp | include 43.247.6.0
*> 43.247.6.0/24   0.0.0.0                  0         32768 i
#sh ip bgp | include 43.247.7.0
*> 43.247.7.0/24   0.0.0.0                  0         32768 i
#sh ip bgp | include 43.247.8.0
*> 43.247.8.0/24   0.0.0.0                  0         32768 i
#sh ip bgp | include 43.247.9.0
*> 43.247.9.0/24   0.0.0.0                  0         32768 i
Hi ,
 Can you join this webex meetings for online support
https://meetings.webex.com/collabs/meetings/join?uuid=MEFV59M1BOK2CMKNYQ4ZRVO1YI-512H
Hi Sir,
My browser doesn't support java right now... That's why I am not able to connect to your invitation...
Okay , I have opened the meeting , you can join whenever u want
 Please share me below outputs again
Sandy
Hi Sir,
here's result:
sh ip bgp neighbors 103.16.17.209 advertised-routes
BGP table version is 2870893, local router ID is 103.225.6.2
*> 103.225.6.0/24  0.0.0.0                  0         32768 i
*> 103.225.7.0/24  0.0.0.0                  0         32768 i
*> 103.225.9.0/24  0.0.0.0                  0         32768 i
 Description: Radius
  BGP state = Established, up for 23:17:59
  Last read 00:00:00, hold time is 180, keepalive interval is 60 seconds
  Message statistics:
    InQ depth is 23
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:               10     475031
    Keepalives:          1400          2
    Route Refresh:          0          0
    Total:               1411     475034
  BGP table version 2871222, neighbor version 2871142
                                 Sent       Rcvd
    Prefixes Current:               3     508129 (Consumes 25423296 bytes)
    Prefixes Total:                15    2314001
    Implicit Withdraw:             12    1771630
    Explicit Withdraw:              0      34242
    Used as bestpath:             n/a     435652
    Saved (soft-reconfig):        n/a      21531 (Consumes 1033488 bytes)
Outbound    Inbound
    route-map:                           28          0
    filter-list:                     820355          0
    prefix-list                          20          0
    Suppressed duplicate:                 0     157471
    AS_PATH loop:                       n/a          7
    Bestpath from this peer:        3714868        n/a
    Total:                          4535291     157478
  Last reset never
Event Timers (current time is 0x5002EFC):
Retrans          1407          1             0x0
TimeWait            0          0             0x0
AckHold         15191       2100             0x0
SendWnd             0          0             0x0
KeepAlive           1          0             0x0
GiveUp              0          0             0x0
PmtuAger            0          0             0x0
DeadWait            0          0             0x0
iss:  786668411  snduna:  786695626  sndnxt:  786695626     sndwnd:  31970
irs: 3197216748  rcvnxt: 3233753908  rcvwnd:      16089  delrcvwnd:    295
SRTT: 305 ms, RTTO: 343 ms, RTV: 38 ms, KRTT: 0 ms
Rcvd: 27795 (out of order: 6), with data: 26400, total data bytes: 36537159
Sent: 27131 (retransmit: 1, fastretransmit: 0), with data: 1405, total data bytes: 27214
BGP table version is 2871652, local router ID is 103.225.6.2
*                   0.0.0.0                            32768 i
I do see
Sandy
