06-28-2004 01:12 PM - edited 03-02-2019 04:41 PM
I want to change management IP of 6509 in topology services to loopback address, but when I select change management IP its not listed. I tried to rediscover deive and get the same thing, loopback is not listed.
any ideas?
06-28-2004 01:51 PM
Did you used the loopback address as the seed ip for the doing the device discovery?. Also see: http://www.cisco.com/warp/public/cc/pd/wr2k/cpmn/prodlit/wk2ke_wp.htm
06-28-2004 06:12 PM
I didnt originally setup system, need to check this. How would I fix this, delete device,, make ANI change
and when rediscover device?
06-30-2004 07:17 AM
06-30-2004 07:17 AM
I had the same problem with ANIServer not detecting the loopback address for Catalyst Switch on my network. I discovered in the ANIServer.properties file located $NNMSROOT\Campus\etc\cwsi a property for telling ANIServer to use the loop address. Just change nameserver.useloopbackaddress to = true. Save the file and then stop and start the ANIServer process.
Hope this helps.
