We have a Paradyne 9580 that is converting from an MCI ATM network to frame-relay on a Cisco 7200 Hssi port. The other end connects the MCI ATM network directly into a native ATM card on another 7200 (PA-A3 card).
The Paradyne is using 'transparent' mode, and from what I have read on Cisco web, when using this mode for internetworking, we should use frame-r encapsulation of ietf, and atm encap of aal5nlpid.
Will this work? Currently, we have atm encap of aal5snap configured, and I can't ping either side. Also, will this atm encap allow for full ip routing tables to be passed between routers?
Chuck
