05-09-2006 01:35 PM - edited 03-03-2019 03:09 AM
Configuring a 2611 for a test environment. Pretty basic - 2 interfaces. E0/0 connects to network, E1/0 connects to test network. E0/0 10.1.1.10 255.0.0.0
E1/0 192.168.100.1 255.255.255.0
Have IP routing turned on with a default route pointing to our pix 10.1.1.1.
I can ping other switches on the real network from the 2611 and into the 192 network.
I can ping from the network switches to the router and beyond. I can not ping past the 10.1.1.100 interface from the 192 network.
Any thoughts?
05-09-2006 02:20 PM
I assume the device beyond the router is PIX. Your PIX mayn't have a route to get to the 192.168.100.0/24 network.
Things you need to make sure:
1. Devices on the 192.168.100.0/24 NET has to be configured with a gateway address of 192.168.100.1
2. All devices beyond the router have a route back to the 192.168.100.0 or their default gateway should be pointing to 2611.
HTH,
Sundar
*Please rate all helpful posts.
05-09-2006 03:24 PM
You may want to verify your subnet masks on all pf the attached devices.
If one of the 10.x.x.x masks are set to something like a 24 bit mask, you'll see the kind of behavior you describe.
This and / or the suggested route issues are the most common mistakes.
Good Luck
Scott
