Point to Point ISDN Connection Issues
jhowland
I have two Routers, a 804, and 802, and two std ISDN lines. (leased line is not available) I am trying to set-up a dial link between the two that will be able to use both channels and get the full 128k. but every time we set up PPP multilink it will only dial one channel, then when it meets the threshold it will drop the first call and dial the second using the second phone number. Is PPP not the way to go, and what about having to dial 2 phone numbers to get both channels.
Help what am I doing wrong.
any recommended configs could be greatly appreciated.
9 Replies 9
makchitale
Level 6
Level 6
Will need to see the following on both the routers, starting off without any B channel connected & then trying to connect on both the B channels:
PPP is the best way to go....
deb isdn q931/ deb dialer/ deb ppp nego / deb ppp multi
sh run / sh ver
Thanks, Mak.
To start with here are the configs. I will work on getting the debugs during off hours for the system.
Names and numbers changed for protection.
Router 1
ERIK#sho runn
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ERIK
logging buffered 4096 debugging
enable secret 5 *
username ssi password 7 *
dial-peer voice 1 pots
no call-waiting
ring 0
port 1
destination-pattern 5554056
dial-peer voice 2 pots
no call-waiting
ring 0
port 2
destination-pattern 5554369
pots country US
ip subnet-zero
ip dhcp excluded-address 10.0.20.135 10.0.20.200
ip dhcp pool 1
network 10.0.20.128 255.255.255.128
domain-name fake.com
default-router 10.0.20.129
dns-server 192.168.1.5
no ip domain-lookup
isdn switch-type basic-ni
interface Ethernet0
ip address 10.0.20.129 255.255.255.128
no ip directed-broadcast
interface BRI0
description coed to ssi
ip address 10.0.0.246 255.255.255.252
encapsulation ppp
dialer idle-timeout 2147483
dialer map ip 10.0.0.245 name ssi broadcast 6515559055
dialer hold-queue 10
dialer load-threshold 2 outbound
dialer-group 1
isdn spid1 10255540560101 5554056
isdn spid2 10255543690101 5554369
no cdp enable
ppp authentication chap
hold-queue 75 in
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.245
map-class dialer ssi
dialer-list 1 protocol ip permit
Router 2
ssi#sho runn
version 12.0
no service pad
hostname ssi
enable secret 5 *
username ERIK password 7 *
ip subnet-zero
no ip domain-lookup
process-max-time 200
interface Ethernet0
description connected to EthernetLAN
ip address 10.0.20.2 255.255.255.252
interface BRI0
description connected to ERIK
ip address 10.0.0.245 255.255.255.252
encapsulation ppp
dialer map ip 10.0.0.246 name ERIK broadcast
dialer-group 1
isdn spid1 10255590551111
isdn spid2 10255590571111
ppp multilink
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.20.1
ip route 10.0.20.128 255.255.255.128 10.0.0.246
You did remember to set "ppp multilink" on both routers before testing? Only router 2 above is currently configured. Another trick is to try adding "no ip route cache" to the BRI0 interface. Some IOS release / router platform combinations have strange behavior when fast switching DDR interfaces. Turning off fast switching is a quick way to eliminate IOS anomolies as a factor.
Good luck and good hunting!
Vincent C Jones
www.networkingunlimited.com
I assume you had the "ppp multilink" under the BRI of Router1....If yes, then you could be probably running into CSCdx54104 "Cant keep both B-chann on BRI up at same time, alternately go DOWN"
Resolved in 12.2 (latest) /12.2(11)T1.
Thanks, Mak.
Sorry, yes I did have the ppp multilink on the first config, but removed it when I couldn't keep the link up. And forgot to put them in for the purposes of the
Also I thought that CSCdx54104 was only in relation to a 3640. These are 800 series units. Please correct me if I am wrong.
Thanks for all your help.
Jerel
Bugs could be platform specific or IOS image specific ( means, all platforms for that image will be affected).....Actually I filed that bug & since I encountered it on the 3640 platform have the mention of it....probably it could be affecting other platforms too.
Thanks, Mak.
I upgraded both routers, and am still not getting the PPP multilink to come up, But I did find something that does not look right. When I do a sho int, I get
ssi#sho int
BRI0 is up, line protocol is up (spoofing)
Hardware is BRI with U interface
Description: connected to ERIK
Internet address is 10.0.0.245/29
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Last input 00:00:22, output 00:00:22, output hang never
Last clearing of "show interface" counters 8w4d
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
404924 packets input, 1997195 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
26 input errors, 0 CRC, 24 frame, 0 overrun, 0 ignored, 2 abort
400535 packets output, 1742765 bytes, 0 underruns
1 carrier transitions
BRI0:1 is up, line protocol is up
Keepalive set (10 sec)
LCP Open, multilink Open
Last input 00:00:01, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue 0/40, 3454 drops; input queue 0/75, 0 drops
5 minute input rate 0 bits/sec, 1 packets/sec
6291517 packets input, 334821099 bytes, 0 no buffer
494 input errors, 282 CRC, 84 frame, 0 overrun, 0 ignored, 128 abort
5039095 packets output, 774421664 bytes, 0 underruns
2812 carrier transitions
BRI0:2 is down, line protocol is down
LCP Closed, multilink Closed
Closed: CDPCP, IPCP
Last input never, output never, output hang never
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 packets input, 0 bytes, 0 no buffer
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
5984 carrier transitions
On both routers, The thing that is puzzling me is that bri0:2 is down, when I disconnect the call on bri0:1 it comes up. Why would this be?
I don't know this is important but you only have dialer load-threshold on one
router. Working with the TAC on a similar issue I was told it had to be configure on both router.
Yep, Tried this one too. Still didn't help.
Has Anyone done this before, and do you have a sample set of configs. I want to rule out anthing wrong that I may be doing in the config, before going full force into finding issues with IOS software, or lines.
