Policy based Routing problem.
panjwani
Hello everyone,
I am facing problem while routing the HTTP and FTP based LAN Traffic to high speed internet line connected to the Router interface. and the default interface is another low speed internet line. What is happening is , FTP Traffic despite being matched by access-lists is going to low speed line. Notice that I have kept default interface is low speed internet line.
If somebody can assist me in providing me the right configuration, I would be grateful. Thanks,
Sadiq.
millerv
can you post a config ?
Dear,Below are the configs that you requested ,
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ??????
enable secret 5 ??????
enable password 7??????
ip subnet-zero
ip name-server 194.170.1.6
ip name-server 194.170.1.7
isdn switch-type basic-net3
interface Ethernet0/0
ip address 195.229.40.193 255.255.255.240
no ip directed-broadcast
ip route-cache policy
ip policy route-map HTTPPOLICY
interface Ethernet0/1
ip address 192.168.154.10 255.255.255.0
interface BRI1/0
no ip address
shut
interface BRI1/1
description connection to Internet on dialup ISDN 64K
no ip address
encapsulation ppp
dialer rotary-group 1
no cdp enable
no shut
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
interface BRI1/4
no ip address
shutdown
interface BRI1/5
no ip address
shutdown
interface BRI1/6
no ip address
shutdown
interface BRI1/7
no ip address
shutdown
interface Dialer1
description connection to internet on dial up isdn
ip unnumbered Ethernet0/0
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 205741
dialer string 4004444
dialer hold-queue 25
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname ?????
ppp chap password ?????
ppp pap sent-username ???? password ?????
ip route 0.0.0.0 0.0.0.0 dialer1
ip classless
no ip http server
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq domain
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq 4000
access-list 101 permit tcp any any eq 5190
access-list 101 permit tcp any any eq 1433
access-list 101 permit tcp any any eq 569
access-list 101 permit tcp any any eq 1863
access-list 101 permit tcp any any eq nntp
access-list 101 permit tcp any any eq 563
access-list 101 permit tcp any any eq pop3
access-list 101 permit tcp any any eq 995
access-list 101 permit tcp any any eq 1080
access-list 101 permit tcp any any eq 1434
access-list 101 permit udp any any eq 1434
access-list 101 permit tcp any any eq ftp
access-list 101 permit tcp any any eq ftp-data
dialer-list 1 protocol ip permit
route-map HTTPPOLICY permit 10
match ip address 101
set ip next-hop 192.168.154.1
line con 0
exec-timeout 0 0
password 7 121A0A1901040001
login
transport input none
line aux 0
line vty 0 4
password 7 09584B05170003
login
no scheduler allocate
end
I hope you understood the configs.
Eth0/0 = Lan network
Eth0/1 = Fast internet line say ADSL
BRI1/1 = ISDN 64K line
Please assist. thanks.
vinodgupt
sadiq,
Go thru the route maps , that help you to configure this or otherwise post the config.
vinod
Dear Vinod, Thanks for your reply, here is the config that you requested. Thanks.
version 12.0
hostname ??????
ip subnet-zero
interface BRI1/0
no ip address
shut
interface BRI1/1
no ip address
encapsulation ppp
no cdp enable
no shut
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
interface BRI1/4
no ip address
shutdown
interface BRI1/5
no ip address
shutdown
interface BRI1/6
no ip address
shutdown
interface BRI1/7
no ip address
shutdown
interface Dialer1
encapsulation ppp
no ip split-horizon
dialer in-band
dialer-group 1
no cdp enable
ip classless
no ip http server
line con 0
exec-timeout 0 0
login
line aux 0
line vty 0 4
login
end
