Power Supply compatibility for 3850
When I am reviewing the infra and inventory of our network, just found out that several stack switches (WS-C3850-48P) model are using  C3KX-PWR-1100WAC,  - which this power supply model was designed for 3750x and not on data sheet of 3850.
Though it's working for year already, may I know if there would be future issues on this? Thanks in advance :)
Best Regards,
Mark
I have never had an issue with any of them even though there not officially supported between models , 35 and 37s are officially supported to be in either platform but we have moved power supply's around constantly with 38s as well and have never had an issue either , were going a lot longer than a year in some of our stacks that are using different model ps supply's
I cant comment on the power stacks we don't really use them here everything is just dual power
Mark Malone
Hi No issues to worry about the power supply's in X series can work in either 3650s,3750s and 3850s
Thanks for the reply Mr. Malone..
So is it safe to power stack it :)
also one thing.. we have bunch of spares (still on package) of C3K-PWR-1150WAC - I think made it's for 3560..
can be it used on 3850?
Thanks for the help Mr. Malone :)
