Power supply
dandis
We have a 7206 that is running c7200-ds-mz.122-24a.bin with a single power supply.
We keep getting the following messages
Jun 21 22:51:22.473: %ENVM-6-PSCHANGE: Power Supply 1 changed from QCS DC Power Supply to removed
Jun 21 22:59:30.623: %ENVM-6-PSCHANGE: Power Supply 1 changed from removed to QCS DC Power Supply
Why the router adds this power supply then remnoves it when in fact there is no power supply 1 at all.
Any help will be appreciated.
wprt000#sho env all
Power Supplies:
Power supply 1 is empty.
Power supply 2 is Zytek AC Power Supply. Unit is on.
wprt000#sho env all
Power Supplies:
Power supply 1 is QCS DC Power Supply. Unit is off.
josrankin
This is a known issue. It's cosmetic. See http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdj14799
Release note:
"7206 chassis with single power supply may generate
repeated power supply change
messages as follows:
Zytek DC Power Supply to
removed
removed to Zytek DC Power
Supply
due to floating PS0_ID or PS1_ID signals when the
power supply slot is empty.
It was fixed in 7204 midplanes. 7206 customers may
disable these messages by
doing:
router# conf t
router(config)# logging con notification
router# end
Only informational and debug messages will be
turned off as a result."
