09-17-2002 03:19 PM - edited 03-02-2019 01:26 AM
We will have a 3660 with an E1 and digital modem card(NM-1CE1U and NM-30DM) and also an NM-8AM. Both of these will have a discrete hunt group number. Is it possible to configure callback whereby if you dial into the analogue modems callback will only be performed by the analogue modems and equally if you dial into the PRI(analogue or digital) callback will be only performed by the PRI. If you can do such a thing what would a config look like? Any help would be much appreciated.
Cheers,
Marcus.
09-18-2002 02:06 PM
Under the NM-8AM lines configure "no modem dialout controller E1 slot/port", and under the remaining lines configure "modem dialout controller E1 slot/port"; this should prevent 8AM calls from trying to use the controller (PRI) while allowing the 30DM to use it.
09-18-2002 09:38 PM
Mmm. the documentation seems to state that is only supported on the ASxxxx boxes. I just went into a 3660 and this command didn't seem to be available. Do you think there might be another way to do this?
Cheers.
09-19-2002 09:07 AM
This command was extended to the 3600 with CSCdm42742; however, you'll need the latest 12.2T code to get this.
09-19-2002 01:30 PM
Thanks very much Mark.
