problem on topology map
aborres
We have ciscoworks2000 LMS 1.0, we have two local routers one is connected to remote sites using leased line HDLC and the other is connected to remote sites using frame relay. there is no problem with routers using HDLC it appearing on the topology map view but the routers using frame relay connection doesn't show on the topology map it showing in unconnected device map. is there any way to show remote routers connected to local router using frame relay on the topology map. thanks
cmadoery
you get all information vie CDP and SNMP requests. make shur its running and allowd.
Christof
