11-10-2003 11:34 AM - edited 03-02-2019 11:36 AM
I have a card wic-1t in router 2610(12.2), but same the single one supports to me until 1728Kbytes.. But the client tien contracted a E1.. is necessary to form something in special in router so that the card can arrive until 1920Kbytes
11-10-2003 02:39 PM
The card supports 1924 Kbps. Check further with your service provider, the clock he is providing you.
11-11-2003 05:22 AM
But if I place a Cisco 3810 if I can arrive at 1920Kbps..... But with single Cisco 2610 it can have the speed of 1728. Exists difference between the Serial Interface of 3810 and one wic-1t... because it works?
please help me.....
11-11-2003 05:49 PM
Check if your CSU/DSU timeslots are in multiples of 56 or 64 K. Also verify if you are using the appropriate cable to your CSU/DSU.
64x30=1920Kbps
56x30=1680Kbps
Is the card recognised in the "show diag" command, try to reseat it properly.
11-12-2003 07:30 AM
hello
The timeslots ISP is multiples 64K.
Router works until the speed of timeslots 27 => 27*64=1728Kbps
but no works aftter the timeslots 27.
the LMI in unstable
Please help me
My sh.diag cisco 3810
Slot 0:
C2610 1E Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 0.0
PCB Serial Number : JAD06240B7G (3910776125)
Part Number : 73-2839-15
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 91 41 00 00 C1 18 4A 41 44 30 36 32
0x10: 34 30 42 37 47 20 28 33 39 31 30 37 37 36 31 32
0x20: 35 29 82 49 0B 17 0F 04 00 81 00 00 00 00 42 41
0x30: 30 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
Serial 2T (12in1)
Hardware revision 1.0 Board revision B0
Serial number 14841591 Part number 800-03181-01
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 12 01 00 00 E2 76 F7 50 0C 6D 01 00 00 00 00
0x30: 58 00 00 00 99 06 28 00 FF FF FF FF FF FF FF FF
